    Boolean Button User Data [SOLVED]
    7 Posts 0 Posters 823 Views
      On 13/12/2016 at 09:25, xxxxxxxx wrote:
      Hello there,
      Is it possible to create a boolean button user data with python as in the screenshot below:
      C4D File : boolean_button.c4d
      Also, is it possible to copy user data from one object to another using python?
      Thanks.
        On 14/12/2016 at 00:37, xxxxxxxx wrote:
        Have look at this thread https://developers.maxon.net/forum/topic/7277/8420_special-options--creating-userdata-with-python
        You got everything you need about creating / copy UD
        And you can also read this tutorial for a better understanding http://www.grooff.eu/tutorials/Adding User Data using Python.pdf
          On 14/12/2016 at 01:15, xxxxxxxx wrote:
          it seems one can create such a boolean button by creating a boolean user data parameter and using the custom GUI of a button:
          bc = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BOOL)
          bc.SetString(c4d.DESC_NAME, "Button")
          bc.SetInt32(c4d.DESC_CUSTOMGUI, c4d.CUSTOMGUI_BUTTON)
          op.AddUserData(bc)
          You find the functions to handle user data in the description of the BaseList2D class.
            On 14/12/2016 at 14:31, xxxxxxxx wrote:
            Thanks so much for your replys, thats works the boolean button.
            I have a new problem : I wanted to add a Font Data Type but I dont know how to do that. i have checked in this list : c4d.GetCustomDataTypeDefault() but I don't found the font data type.
            Thanks again.
              On 14/12/2016 at 17:41, xxxxxxxx wrote:
              https://developers.maxon.net/docs/py/2023_2/modules/c4d/CustomDataType/FontData/index.html
              I guess it's that but not sure 😉
                On 15/12/2016 at 02:26, xxxxxxxx wrote:
                Here's how to simply create a FontData user data:
                bc = c4d.GetCustomDatatypeDefault(c4d.FONTCHOOSER_DATA)
                bc[c4d.DESC_NAME] = 'FontUserData'
                bc[c4d.DESC_SHORT_NAME] = 'FontUD'
                op.AddUserData(bc)
                To enable the font size popup:
                bc[c4d.FONTCHOOSER_ENABLE_SIZE] = True
                  On 16/12/2016 at 07:14, xxxxxxxx wrote:
                  Thank you guys for your help.
