    Сreation ObjectPlugin (AttributeError) [SOLVED]
    8 Posts 0 Posters 492 Views
      On 26/10/2016 at 03:02, xxxxxxxx wrote:
      I'm trying to create a plugin.
      I cannot get ID BOOL.
      Prompt me please where I have an error
      ConsoleLog:
      AttributeError: 'module' object has no attribute 'ID_TEST1'
      TEST\Test.pyp
      PLUGIN_ID = 1234390
      class Otest(c4d.plugins.ObjectData) :
       def Init(self, op) :
        print c4d.ID_TEST1,c4d.ID_TEST2,c4d.ID_TEST3
       def GetVirtualObjects(self, op, hierarchyhelp) :
        return c4d.BaseObject(c4d.Ocube)
       c4d.plugins.RegisterObjectPlugin(id=PLUGIN_ID,str="Test",g=Otest,description="Otest",icon=None,info=c4d.OBJECT_GENERATOR)
      TEST\res\description\Otest.h
      #ifndef _OTEST_H_
      #define _OTEST_H_
      enum
       Otest=10000,
       ID_TEST_GROUP=10014,
       ID_TEST1=1015,
       ID_TEST2=1016,
       ID_TEST3=1017,
      #endif
      TEST\res\description\Otest.res
      CONTAINER Otest
       NAME Otest;
       INCLUDE Obase;
       GROUP ID_TEST_GROUP
        BOOL ID_TEST1 { ANIM OFF; }
        BOOL ID_TEST2 { ANIM OFF; }
        BOOL ID_TEST3 { ANIM OFF; }
      TEST\res\strings_us\description\Otest.str
      STRINGTABLE Otest
       Otest "Otest";
       ID_TEST_GROUP "TEST";
       ID_TEST1 "TEST1";
       ID_TEST2 "TEST2";
       ID_TEST3 "TEST3";
        On 26/10/2016 at 04:51, xxxxxxxx wrote:
        C4D adds the resources of a registered plugin to the c4d main module and writes them to "userfolder/prefs/coffeesymbolcache". If you change your resource files, just remove this file and restart C4D. I hope this helps.
        Cheers, Sebastian
          On 26/10/2016 at 04:53, xxxxxxxx wrote:
          It is an issue with the Cinema 4D symbol cache. You can search here in the forum about it. Basically, the
          issue is that it is not updated when you change your description, only once when the description file is
          newly discovered by Cinema 4D.
          Personally, I never rely on the symbols to be exported into C4D. Also you can not use the symbols from
          c4d_symbols.h (for your Dialogs) anyway. I always export them into a separate file or format them so I
          can easily copy & paste them into the .pyp file.
          More information here
          https://github.com/nr-plugins/c4ddev
          https://github.com/nr-plugins/c4ddev/wiki/c4ddev_commandline#symbols
            On 26/10/2016 at 05:17, xxxxxxxx wrote:
            NiklasR, thank you
              On 27/10/2016 at 03:31, xxxxxxxx wrote:
              Tell me again. How to make ID_TEST2 inactive in this plugin?
              When you enable ID_TEST1 to do inactive ID_TEST2
              "self.Enable(c4d.ID_TEST2, False)" in def GetVirtualObjects not work
                On 27/10/2016 at 08:09, xxxxxxxx wrote:
                your plugin is a ObjectData plugin based on NodeData. There is no "Enable" function to call.
                To enable or disable parameters dynamically you have to implement NodeData.GetDEnabling().
                  On 27/10/2016 at 22:37, xxxxxxxx wrote:
                  Tell me how to block modifies curent object in polygonobject
                  Maybe so
                  def Message(self, node, type, data) :
                  	if type==c4d.MSG_EDITABLE_END:
                  		return False
                  But so does not work
                  def Message after
                  "Message" function is executed after "Make Editable"?
                    On 28/10/2016 at 00:10, xxxxxxxx wrote:
                    for questions no longer related to the thread's original topic please open a new thread. Thanks.
