Safeframe to Render Resolution [SOLVED]
On 13/10/2016 at 05:17, xxxxxxxx wrote:
Hi there,
comparing the safeframe aspect with the renderaspect by using the BaseDraw( ).GetSafeFrame() function in the way described later , always gives me wrong results.
How should we calculate the resulting resolution from e.g. mouse recognition data; or the other way round,
which calculation/values uses the "copy from IRR" button??Can anybody help me solving it, please?
best wishes
Martinimport c4d,math def main() : # compare BaseDrawResolution and RenderResolution doc = c4d.documents.GetActiveDocument() bd = doc.GetActiveBaseDraw() if bd is None: return rd = doc.GetActiveRenderData() rdata = rd.GetData() xren = rdata[c4d.RDATA_XRES] yren = rdata[c4d.RDATA_YRES] rendersafe = bd.GetSafeFrame()#safe frame xsafe = float(rendersafe["cr"]) - float(rendersafe["cl"]) ysafe = float(rendersafe["cb"]) - float(rendersafe["ct"]) print xsafe, "xsafe" print ysafe, "ysafe" print xsafe/ysafe, "aspectSAFE" print rdata[c4d.RDATA_FILMASPECT], "aspectRENDER" print xren/xsafe, yren/ysafe,"SAFEtoREN" if __name__=='__main__': main()
On 14/10/2016 at 01:27, xxxxxxxx wrote:
I don't fully understand what you are trying to do here. But I'm wondering why your are comparing the safe frame dimensions of a BaseDraw with the render settings. The safe frame of a BaseDraw window depends on the resolution of that BaseDraw. That resolution is obtained with GetFrame().
Sebastian -
On 14/10/2016 at 06:04, xxxxxxxx wrote:
Hi Sebastian,
let´s kepp it simple and say: I want to do the calculation the "copy from IRR" button does.
If I do my calculation on the dimension(let´s say x) of a bas draw where no safeframe is shown,
the calculation is correct.
If I try the same with the y-dimension subtracting the safeframe delta from the drawviewframe the calculation is sometimes right sometimes not.Thanks for your help
Martinimport c4d,math def main() : # compare BaseDrawResolution and RenderResolution doc = c4d.documents.GetActiveDocument() bd = doc.GetActiveBaseDraw() if bd is None: return rd = doc.GetActiveRenderData() rdata = rd.GetData() xren = rdata[c4d.RDATA_XRES] yren = rdata[c4d.RDATA_YRES] rendersafe = bd.GetSafeFrame()#safe frame xsafe = float(rendersafe["cr"]) - float(rendersafe["cl"]) ysafe = float(rendersafe["cb"]) - float(rendersafe["ct"]) # get base view viewsize = bd.GetFrame() xview = viewsize ["cr"] yview = viewsize ["cb"] print xview, "xview" print yview, "yview" # get data bc = bd.GetDataInstance() if bc is None: return # get subcontainer of IRR and it´s data subcontainer = bc.GetContainer(430000020) xleft = xview*subcontainer.GetReal(0)#or right FLIP!! xright = xview*subcontainer.GetReal(2)#or left FLIP!! ytop = yview *subcontainer.GetReal(1)#or bot FLIP!! ybot = yview*subcontainer.GetReal(3)#or top FLIP!! # check and swap of IRR values if xright<xleft: xleft,xright = xright,xleft if ybot<ytop: ytop,ybot = ybot,ytop print xleft, xright, ytop, ybot, "Res of irr" xIRR = abs(subcontainer.GetReal(0)-subcontainer.GetReal(2))*xview yIRR = abs(subcontainer.GetReal(1)-subcontainer.GetReal(3))*yview print xIRR, yIRR, "IRR drawsize" # try several conversions xdelta=((xsafe-xview)) ydelta=((ysafe-yview)) print xdelta,ydelta,"deltas" # decide which factor view to rendersize factor = 0.0 if xdelta==0.0: factor = xren/xsafe else: factor = yren/ysafe print factor, "factor on view" xsaview = xsafe/xview ysaview = ysafe/yview print ysaview ,"view to safe", xsaview #find IRR in renderspace 'test x without safeframe area' 'ok so far' print math.floor(xleft*factor), "left" print xren-math.ceil(xright*factor), "right" 'here wrong results with the safeframe' print round((ytop-rendersafe["ct"])*factor), "top" if __name__=='__main__': main()
On 14/10/2016 at 14:17, xxxxxxxx wrote:
again...
Even if I only use the basedraw´s frame resolution and the renderaspect,
I´ll only somtimes get the right values.
What is c4d´s convention of rounding those values or how they are calculatedthanks in advance
martinimport c4d,math def main() : # compare BaseDrawResolution and RenderResolution doc = c4d.documents.GetActiveDocument() bd = doc.GetActiveBaseDraw() if bd is None: return # get base view viewsize = bd.GetFrame() xview = viewsize ["cr"] yview = viewsize ["cb"] # get data bc = bd.GetDataInstance() if bc is None: return # get subcontainer of IRR and it´s data subcontainer = bc.GetContainer(430000020) xleft = xview*subcontainer.GetReal(0)#or right FLIP!! xright = xview*subcontainer.GetReal(2)#or left FLIP!! ytop = yview *subcontainer.GetReal(1)#or bot FLIP!! ybot = yview*subcontainer.GetReal(3)#or top FLIP!! # check and swap of IRR values if xright<xleft: xleft,xright = xright,xleft if ybot<ytop: ytop,ybot = ybot,ytop # decide which factor and aspect, view to rendersize rd = doc.GetActiveRenderData() rdata = rd.GetData() xren = rdata[c4d.RDATA_XRES] yren = rdata[c4d.RDATA_YRES] aspectren = rdata[c4d.RDATA_FILMASPECT] aspectview = float(xview)/float(yview) factor = 0.0 safex = 0.0 safey = 0.0 if aspectren>=aspectview: factor = xren/xview safey = (yview-xview/aspectren)*0.5 else: factor = yren/yview safex = (xview-yview*aspectren)*0.5 # get IRR values in renderspace left = max(math.floor((xleft-safex)*factor), 0) right = max(xren-math.ceil((xright-safex)*factor),0) top = max(math.floor((ytop-safey)*factor),0) bot = max(yren-math.ceil((ybot-safey)*factor),0) # compare with irr button print left,"left" print right, "right" print top, "top" print bot, "bot" if __name__=='__main__': main()
On 17/10/2016 at 04:28, xxxxxxxx wrote:
inside the "Copy from IRR" functionality there is a lot of casting, adding and scaling happening. I tried to recreate the handling of the width in Python:
bd = doc.GetActiveBaseDraw() if bd is None: return viewsize = bd.GetFrame() cr = viewsize['cr'] cl = viewsize['cl'] w = (cr - cl) + 1 bc = bd.GetDataInstance() if bc is None: return subcontainer = bc.GetContainer(430000020) x1 = subcontainer.GetFloat(0) x2 = subcontainer.GetFloat(2) rendersafe = bd.GetSafeFrame() mr = rendersafe["cr"] ml = rendersafe["cl"] rd = doc.GetActiveRenderData() rdata = rd.GetData() xres = rdata[c4d.RDATA_XRES] scale = float(xres) / float(mr - ml + 1) left = int((x1 * w + cl - ml) * scale) right = int(xres -(x2 * w + cl - ml) * scale) print(left) print(right)
Sebastian -
On 17/10/2016 at 11:43, xxxxxxxx wrote:
Hi Sebastian,
I see, adding one pixel has it´s benefits e.g. avoiding divisions by zero.
But it seem a bit odd to me that even for the calculation of the y values the relation xsafe to xrender resolution is used.Thanks for your time! That helped a lot !
Martin -
On 20/10/2016 at 01:14, xxxxxxxx wrote:
Hi there,
if somone tracks this topic....
Investigating further, the calculation behind the Irr button leads to wrong results.
Especially if the relation between viewport and desired render resolution get´s taller,
one wont be able to get pixels on the lower border.
I´ve sent a report to Maxon, so I guess this issue will be fixed in further releases and the presented solution will be obsolete. (state: Cinema 4D R18.028)best wishes
Martin
