    Dynamic Render Region
    11 Posts 0 Posters 1.3k Views
      On 18/07/2016 at 19:30, xxxxxxxx wrote:
      Ok, I found a way to bake the information.
      Also, I have a way to know if the main external renderer is happening.
      I'm loading the baked results in the Render Region of the active render but it is not updating.
      What type of message must I send to my document or to the render data to make it update during render?
        On 19/07/2016 at 01:58, xxxxxxxx wrote:
        as always a tag should only store data or modify the host object. A tag (or to be more precise: a tag's Execute() function) should not modify the scene, especially not during rendering.
        Please post some code that shows what exactly you are doing.
          On 19/07/2016 at 02:41, xxxxxxxx wrote:
          Hello Sebastian
          The snippet of the Execute code that is trying to adjust the Render Region is this one:
              def Execute(self,tag,doc,op,bt,priority,flags) :
              	if op==None: return c4d.EXECUTIONRESULT_OK
              	if c4d.threading.GeIsMainThread() == False:
              		the_thread = c4d.threading.GeGetCurrentThread()
              		render = c4d.threading.IdentifyThread(the_thread) == c4d.THREADTYPE_RENDEREXTERNAL
              		if render==True:
              			bc0=tag.GetData()
              			# the data is stored inside a container with ID=10000
              			bc1=bc0.GetData(10000)
              			if bc1==None: return c4d.EXECUTIONRESULT_OK
              			fps=doc.GetFps()
              			ctime = doc.GetTime().GetFrame(fps)
              			bc2=bc1.GetData(ctime)
              			if bc2 != None:
              				rd=doc.GetActiveRenderData()
              				# each four values are stored inside a container with ID equal to the frame number
              				rd[c4d.RDATA_RENDERREGION_LEFT]=bc2.GetLong(0)
              				rd[c4d.RDATA_RENDERREGION_RIGHT]=bc2.GetLong(1)
              				rd[c4d.RDATA_RENDERREGION_TOP]=bc2.GetLong(2)
              				rd[c4d.RDATA_RENDERREGION_BOTTOM]=bc2.GetLong(3)
              				doc.SetActiveRenderData(rd)
              				doc.Message(c4d.MSG_UPDATE)
              			# the rest of the Execute code
            On 19/07/2016 at 06:36, xxxxxxxx wrote:
            I will be soooooo sad if this isn't possible 😞
              On 19/07/2016 at 09:08, xxxxxxxx wrote:
              as you know, rendering is done using the RenderDocument() function. The second argument of the function is a BaseContainer that contains the render settings.
              Cinema 4D will (mostly) use the content of this BaseContainer to get the relevant settings for the given rendering process. As the data in this container is static, it cannot be changed during rendering.
                On 19/07/2016 at 09:31, xxxxxxxx wrote:
                So, I will have to create my own rendering command, rendering each frame individually and adjusting the container for each frame, right?
                  On 19/07/2016 at 23:12, xxxxxxxx wrote:
                  rendering each frame individually of course would work. But such a solution might not support inter-frame effects like motion-blur etc.
                    On 20/07/2016 at 00:24, xxxxxxxx wrote:
                    Oh, damn!! 😞
                    Well, I will have to warn about those limitations.
                      On 25/07/2016 at 00:00, xxxxxxxx wrote:
                      Rui Batista , your plugin not work as expected.
                      It does not work on my character
                      File "'Dynamic IRR.pypv'", line 729, in Execute
                      AttributeError: 'c4d.modules.character.CAJointObject' object has no attribute 'GetAllPoints'
                        On 25/07/2016 at 00:07, xxxxxxxx wrote:
                        Thank you.
                        I will check for Joints and I will update the code as soon as possible.
