    • Admin
    How to get Multipass selected in Render Settings
    4 Posts 0 Posters 335 Views
      On 20/03/2016 at 11:50, xxxxxxxx wrote:
      Cinema 4D Version:   17
      Language(s) :       PYTHON  ;
      Hi, guys!
      How to get Multipass selected in Render Settings?
      i try this code, but it don't works. What's wrong?
          rd = doc.GetActiveRenderData()
          vp = rd.GetFirstMultipass()
          while vp:
              if vp.GetTypeName() == 'Object Buffer' and vp.GetBit(c4d.BIT_ACTIVE) :
                  print vp.GetName()
              vp = vp.GetNext()
        On 20/03/2016 at 18:14, xxxxxxxx wrote:
        Have you simply checked to see if vp.GetBit(c4d.BIT_ACTIVE) works (without name checking)?
        If not, it is possible that this state is not set for MultipassObjects.
          On 21/03/2016 at 06:33, xxxxxxxx wrote:
          the bit you are looking for is actually BIT_VPDISABLED instead of BIT_ACTIVE. Also note the inverted logic of that bit (true means "not enabled").
          Hope you don't mind, I have moved the thread into the Python subforum.
            On 24/03/2016 at 15:25, xxxxxxxx wrote:
            Thanks, guys!
