    Listen Specific UserData field [SOLVED]
    5 Posts 0 Posters 707 Views
      On 19/03/2016 at 23:15, xxxxxxxx wrote:
      Hi, i need to execut some functions from my script everytime when user change something in one user data field. Im just a beginer in python sdk and i dont understand very well how it works but i thought a little and i made for my userdata field that i want to listen a clone  and i hide it from script(just to store the old value) and i compare always with main field. If something changed i do something. In may case i just change the value of chekbutton.
      here my script:
          obj = op.GetObject() #get an object with python tag
          ud = obj.GetUserDataContainer() #get an userdata container
          ud[2][1][c4d.DESC_HIDE] = True #hide my field copy
          obj.SetUserDataContainer(ud[2][0], ud[2][1])
          new = obj[c4d.ID_USERDATA,1] #value of my filed that i want to listen
          old = obj[c4d.ID_USERDATA,3]  #value of clone
          if old != new:
              obj[c4d.ID_USERDATA,2] = 1 - obj[c4d.ID_USERDATA,2] #change value of radiobutton to oposite
              obj[c4d.ID_USERDATA,3] = new #store value of my field to clone
      So it works well but it looks like a trick. Is there other method to listen a change in userdata filed?
        On 21/03/2016 at 03:07, xxxxxxxx wrote:
        what exactly do you mean with "script"? Do you mean a script that is stored and executed from the Script Manager? A script in the Script Manager can only be executed from that Script Manager, it cannot be triggered by an event.
        Or is your script stored in a Python Tag? Then the best way would be indeed to store the old value in another user data field and compare it with the current value.
          On 21/03/2016 at 05:09, xxxxxxxx wrote:
          From python tag. Thank you.
            On 21/03/2016 at 05:26, xxxxxxxx wrote:
            You can store the old value without an additional user data field.
            G = {}
                value = op[c4d.ID_USERDATA, 1]
                if value != G.get('old_value') :
                    # Value changed or first time the script is run (eg. if
                    # the scene was just opened).
                    G['old_value'] = value
            Best,
            Niklas
              On 21/03/2016 at 07:30, xxxxxxxx wrote:
              good method NiklasR. Thank you
