A Question on GetActiveObject? [SOLVED]
On 07/11/2015 at 12:39, xxxxxxxx wrote:
Hi Guys,
I use GetActiveObject to Select active object, that is in the Object List.
Now when i use doc.GetActiveObject it dont work right.
It separate them and not group them.
This What *Console* Said:
AssertionError: Found next objects. Please add them separately.So I wanted It to generate with the selected object use choose and go under or become a child.
Code:
def Generator_TAXILINE(self) :doc = c4d.documents.GetActiveDocument()
#--| Generate and SET NAMES |--#
#Generate Sweep
taxi_sweep_Name = c4d.BaseObject(c4d.Osweep)
taxi_sweep_Name.SetName("TaxiLine")#User Custom TEMP
TEMP_Name = self.linkBox.GetLink()
TEMP_Name.SetName("TAXILINE_TEMP")#Select User Custom Path
selectedobject = doc.GetActiveObject() # <----| this Problem
selectedobject.SetName("User-Custom-Path")
#Insert Objects To LIST!
doc.InsertObject(taxi_sweep_Name)
doc.InsertObject(TEMP_Name)
doc.InsertObject(selectedobject)# Objects Order!
parent = doc.SearchObject("TaxiLine")
child_Temp = doc.SearchObject("User-Custom-Path")
child_Temp.InsertUnder(parent)
child_Temp = doc.SearchObject("TAXILINE_TEMP")
return True#--|C.O.M.M.A.N.D.S|-------------------------------------------------------#
def Command (self, id, msg) :
if (id == GEN_BUTTON) :
self.Generator_TAXILINE()
This what is happen when excute with doc.GetActiveObject() :
But If i use selectedobject = c4d.BaseObject(c4d.Osplinecircle) , IT WORKS FINE:
Help or Tip,
Ashton,
sorry for my English guys. -
On 07/11/2015 at 14:02, xxxxxxxx wrote:
In your code sample, you first select an object out of the existing tree:
and then you try to insert that somewhere else:
doc.InsertObject(selectedobject)I suppose C4D doesn't like that much. You should cut that object from the tree first, to isolate it. Then you can insert it somewhere else.
In your second sample,
you create a new object, which naturally is not connected in the tree already, and insert that. This is uncritical, and therefore works. -
On 07/11/2015 at 15:58, xxxxxxxx wrote:
thanks man
IT WORKS BRO!
CODE:
def User_Custom_Path(self) :
selectedobject.SetName("User-Custom-Path")def Generator_TAXILINE(self) :
self.User_Custom_Path()
c4d.CallCommand(12298, 12298) # Model
#Generate Sweep
taxi_sweep_Name = self.linkBox2.GetLink().GetClone(c4d.COPYFLAGS_0)
#User Custom TEMP
TEMP_Name = self.linkBox.GetLink().GetClone(c4d.COPYFLAGS_0)
TEMP_Name.SetName("TAXILINE_TEMP")#Insert Objects To LIST!
#doc.InsertObject(selectedobject)# Objects Oder!
parent = doc.SearchObject("TaxiLine")child_Temp = doc.SearchObject("User-Custom-Path")
child_Temp.InsertUnder(parent)child_Temp2 = doc.SearchObject("TAXILINE_TEMP")
child_Temp2.InsertUnder(parent)c4d.EventAdd()
Thanks Cairyn
Ashton
