    Load MultipassBitmap [SOLVED]
    8 Posts 0 Posters 719 Views
      On 20/10/2015 at 04:10, xxxxxxxx wrote:
      Hi there,
      I couldn't find a way to load a MultipassBitmap from a file. The constructor already requires to define the
      resolution and bitdepth of the MultipassBitmap. If I initialize it with 0, 0, 0 and use InitWith() (inherited
      from BaseBitmap), a StandardError is raised with the message "This operation can only handle
      BaseBitmaps.".
      TIA,
      Niklas
        On 21/10/2015 at 01:37, xxxxxxxx wrote:
        to load images with layers you can use the functions of BodyPaint. Something like this:
        bc = c4d.BaseContainer()
        bc.SetFilename(c4d.LOADTEXTURE_FILENAME, path)
        tex = c4d.modules.bodypaint.SendPainterCommand(c4d.PAINTER_LOADTEXTURE, doc=doc, tex=None, bc=bc)
        if tex is None:
        layer = tex.GetFirstLayer()
        while layer is not None:
             print(layer.GetName())
             layer = layer.GetNext()
        See also "Parsing PSD layers in MultipassBitmap".
          On 21/10/2015 at 03:20, xxxxxxxx wrote:
          Thanks Sebastian, that should be sufficient for my purpose, I don't need it as a MultipassBitmap. 🙂
          Only that I'd like to show the image in the Picture Viewer, but I guess that won't work with a PaintTexture.
          Cheers!
            On 22/10/2015 at 10:09, xxxxxxxx wrote:
            Hey Sebastian, I just had some time to look at the bodypaint module and its classes. It seems like I can't
            read or write the pixels of a PaintLayerBmp. So there is no way to load an image with multiple layers and
            use that in Python?
            -N
              On 22/10/2015 at 10:59, xxxxxxxx wrote:
              They're gone until Monday Niklas.
              But maybe this will help.
              #This script gets the color data from a BP layer and creates an image from it
              #NOTE: GetSelectedTexture() is only supported in R16++
                #Get the selected bp texture(Usually the image in a material)
                tex = c4d.modules.bodypaint.PaintTexture.GetSelectedTexture()
                texturename = tex.GetFilename()
                #Get the active BP layers (the layer tab in the AM)
                activelayer = tex.GetActive()
                #If the active layer is holding a bitmap image
                if activelayer.IsInstanceOf(c4d.OBJECT_PAINTLAYERBMP) == True:
                    #Convert the layer to an image and store it in memory
                    #Then get it's size values
                    bmp = activelayer.ToPaintLayerBmp()
                    xres = bmp.GetBw()
                    yres = bmp.GetBh()
                    size = xres * yres
                    if size == 0: return
                    #Get the color mode of the image that's in memory
                    colorMode = bmp.GetColorMode()
                    #Store some buffer like data into memory
                    sq = c4d.storage.ByteSeq(None, size*c4d.COLORBYTES_RGB)
                    inc = 3
                    #Read the color data in the image that's currently in memory
                    #Reminder: This image was gotten from a layer..Which was gotten from a channel in a material
                    for row in xrange(yres) :
                        offset = sq.GetOffset(row*(xres*inc))
                        bmp.GetPixelCnt(0, row, xres, offset, colorMode, c4d.PIXELCNT_0)
                    #Create a new image based on the color data we just got above
                    newBitmap = c4d.bitmaps.BaseBitmap()
                    newBitmap.Init(xres,yres,)
                        newBitmap.SetPixelCnt(0, row, xres, offset, inc,colorMode, c4d.PIXELCNT_0)
                    #Save the image to a file on your HD
                    filename = c4d.storage.SaveDialog(title="Save Image")
                    newBitmap.Save(filename,c4d.FILTER_TIF)
                On 22/10/2015 at 12:35, xxxxxxxx wrote:
                Hey Scott, thanks a lot for your example! I missed that GetPixelCnt() and SetPixelCnt() are for getting
                and setting pixel data (I find the names rather confusing for that purpose). Anyway, that is actually exactly
                what I needed. 🙂
                  On 22/10/2015 at 15:38, xxxxxxxx wrote:
                  I couldn't get allocating a new  PaintTexture to work (was always size 0, 0). I also tried copying the
                  contents of the PaintTexture loaded with SendPainterCommand()  to a MultipassBitmap , but the result
                  was just black. Also, I couldn't get layers to work with the MultipassBitmap. Although the layers were
                  there (ie. were returned with .GetLayers()) the Picture Viewer didn't show them.
                  I'll try it in C++ and see if it works there.
                    On 26/10/2015 at 01:49, xxxxxxxx wrote:
                    as Scott pointed out the content of a PaintTexture can be read with GetPixelCnt(). See also "Bodypaint Layer Bitmap".
