    UV Mapping Projection
    13 Posts 0 Posters 2.6k Views
      On 08/10/2015 at 08:13, xxxxxxxx wrote:
      Several years ago I asked how to execute the "Frontal" UV button in BP. And Matthias told me that we cannot execute those buttons.
      I was upset about that. So he (and some other members) posted some code on how to create the UV's like the Frontal button does for me.
      If Maxon can't give us access to these buttons. Then it would be nice if they posted the source code for them.
      AFAIK. The code they use contains nothing secret that they need to keep secret from their competitors. It's all the same maths used by every single software company.
      But math is painful.😂
      It would handy to have the code behind those buttons.
        On 08/10/2015 at 08:31, xxxxxxxx wrote:
        Well that sucks.
        Thanks for taking the time to respond.
          On 08/10/2015 at 09:07, xxxxxxxx wrote:
          as Scott mentions, it is unfortunately not possible to access this functionality.
            On 08/10/2015 at 09:14, xxxxxxxx wrote:
            Thanks for checking into it.  Maybe in the future it will be available via CallCommand.
            I'm writing a productivity script and it would have saved a step.  I can just click the Box button when I'm in BP adjusting the UV to fit the texture.
            I'm pretty happy that python will get me to that point.  Have to leave something for humans to do or I would be out of a job. 😂
              On 09/10/2015 at 08:30, xxxxxxxx wrote:
              Could you point us to the posted code?
              -Pim
                On 09/10/2015 at 12:06, xxxxxxxx wrote:
                The code was posted in C++ so I don't know if it will help you or not:
                https://developers.maxon.net/forum/topic/6483/6972_uv-mirror-hv&KW=Frontal&PN=1
                This is what I have in my C++ notes:
                //This code creates the equivalent to the flat mapping button in the BP UV options
                #define SIGDIG    5.0                   //Define a value macro to be used several times later on
                static Real sign(Real n)
                  if( n > 0.0 )    return 1.0;        //Returns zero by default
                  if( n < 0.0 )    return -1.0;       //Otherwise Returns 1.0 or -1.0
                  return 0.0;
                static Real TrimDecimal(Real num, Real digits)
                  Real n;
                  n = num * Pow((Real)10.0, digits);
                  n = sign(n) * Abs(Floor(n + 0.5));
                  return n / Pow((Real)10.0, digits);
                Bool FrontalMapUVs(PolygonObject *op, Matrix mg)
                  if( !op ) return false;
                  LONG numFaces = op->GetPolygonCount();
                  LONG numVerts = op->GetPointCount();
                  Vector *pVerts = op->GetPointW();
                  CPolygon *pPolys = op->GetPolygonW();
                  UVWTag *pUVTag = (UVWTag * )op->MakeVariableTag(Tuvw, numFaces);
                  if( !pUVTag ) return false;
                  UVWHandle pUVHndl = pUVTag->GetDataAddressW();
                  if( !pUVHndl ) return false;
                  LONG ndx;
                  Real lenxinv, lenyinv, lenzinv;
                  Vector mapCenter, mapSize, vMin, vMax;
                  vMin.x = 100000.0;
                  vMin.y = 100000.0;
                  vMin.z = 100000.0;
                  vMax.x = -100000.0;
                  vMax.y = -100000.0;
                  vMax.z = -100000.0;
                  for(ndx=0; ndx<numVerts; ndx++)
                      Vector pt = pVerts[ndx] * mg;
                      if( pt.x < vMin.x ) vMin.x = pt.x;
                      if( pt.x > vMax.x ) vMax.x = pt.x;
                      if( pt.y < vMin.y ) vMin.y = pt.y;
                      if( pt.y > vMax.y ) vMax.y = pt.y;
                      if( pt.z < vMin.z ) vMin.z = pt.z;
                      if( pt.z > vMax.z ) vMax.z = pt.z;
                  mapSize.x = Abs(vMax.x - vMin.x);
                  mapSize.y = Abs(vMax.y - vMin.y);
                  mapSize.z = Abs(vMax.z - vMin.z);
                  mapCenter.x = vMin.x+(mapSize.x*0.5);
                  mapCenter.y = vMin.y+(mapSize.y*0.5);
                  mapCenter.z = vMin.z+(mapSize.z*0.5);
                  if (mapSize.x!=0.0) lenxinv = 1.0/mapSize.x;    else lenxinv = 0.0;
                  if (mapSize.y!=0.0) lenyinv = 1.0/mapSize.y;    else lenyinv = 0.0;
                  if (mapSize.z!=0.0) lenzinv = 1.0/mapSize.z;    else lenzinv = 0.0;
                  // Walk the list of polygons and map the UVs
                  for(ndx=0; ndx<numFaces; ndx++)
                      UVWStruct uvw;
                      pUVTag->Get(pUVHndl, ndx, uvw);
                      Vector pt_a = (pVerts[pPolys[ndx].a] - mapCenter) + mg.off;
                      Vector pt_b = (pVerts[pPolys[ndx].b] - mapCenter) + mg.off;
                      Vector pt_c = (pVerts[pPolys[ndx].c] - mapCenter) + mg.off;
                      Vector pt_d = (pVerts[pPolys[ndx].d] - mapCenter) + mg.off;
                      uvw.a.x = TrimDecimal((pt_a.x*lenxinv)+0.5, SIGDIG);
                      uvw.a.y = TrimDecimal((-pt_a.y*lenyinv)+0.5, SIGDIG);
                      uvw.b.x = TrimDecimal((pt_b.x*lenxinv)+0.5, SIGDIG);
                      uvw.b.y = TrimDecimal((-pt_b.y*lenyinv)+0.5, SIGDIG);
                      uvw.c.x = TrimDecimal((pt_c.x*lenxinv)+0.5, SIGDIG);
                      uvw.c.y = TrimDecimal((-pt_c.y*lenyinv)+0.5, SIGDIG);
                      uvw.d.x = TrimDecimal((pt_d.x*lenxinv)+0.5, SIGDIG);
                      uvw.d.y = TrimDecimal((-pt_d.y*lenyinv)+0.5, SIGDIG);
                      pUVTag->Set(pUVHndl, ndx, uvw);
                  return true;
                  On 12/10/2015 at 00:24, xxxxxxxx wrote:
                  Thanks again.
                  -Pim
                    Any ideas IF this will be accessible in future SDK updates, and if this future is near or far away?
                    Thanks.
                      On 08/12/2015 at 01:28, xxxxxxxx wrote:
                      currently we cannot make any statements on future releases or API functions.
                        On 23/12/2015 at 01:33, xxxxxxxx wrote:
                        As the original request to access the projection buttons was from 2012, and seeing that these currently still cannot be called from Python (or even C++, if I read correctly) I thought that with the change in communication we finally would get to know if or when more access to the bodypaint module would be provided.
                        Thanks for reading.
