    c4d_strings one file for both OS X and Win[SOLVED]
    SDK Help
    0
    • H
      On 25/07/2015 at 10:45, xxxxxxxx wrote:
      Cinema 4D Version:   15/16
      Language(s) :
      I am having an issue where everything works for my builds on Windows and OS X.  When I create one plugin folder to be used on both the string resources only work on the platform I copied them from ( Windows works for Windows or OS X works for OS X ).
      How do I create one c4d_strings file that works on both?
      Ama
      • H
        On 27/07/2015 at 05:08, xxxxxxxx wrote:
        Hi Ama,
        I'm not aware you have to do anything special. Can you provide me with two string files (one working only on Mac and one working only on Windows), so I can have a look? You can send these to [email protected]
        • H
          On 27/07/2015 at 05:13, xxxxxxxx wrote:
          Thanks!
          I will send them in a few.
          Ama
          Hi Ama,
          • H
            On 27/07/2015 at 08:06, xxxxxxxx wrote:
            Hi Ama,
            thanks for sending the string files. I threw those files (one at a time) into one of my example projects added all symbols to c4d_symbols.h and added code that printed every string via GePrint(GeLoadString()). All strings got printed, no matter which file I used. I did this test on Windows only, as you said neither file would work on the other system. So I think your string files are ok and the reason for failure has to be searched somewhere else.
            • H
              On 02/08/2015 at 06:38, xxxxxxxx wrote:
              I have narrowed down the issue.  It seems to be with the c4d_symbols.h file.  On OS X alone changing the enumeration values changes the index into the string table.  None of the actual enumerations or string table have changed, only the indices associated with the c4s_symbols.h:
              Example:
              enum
                  S_OBJECT_TITLE = 10000,
                  S_INNERDENSITY_TITLE = 10040,
              becomes:
              enum
                  S_OBJECT_TITLE = 10040,
                  S_INNERDENSITY_TITLE,
              Now the string returned from the string table is the one before.  The string table did not change.
              Are the enumeration values from the string table cached?
              regards,
              Ama
              • H
                On 02/08/2015 at 08:23, xxxxxxxx wrote:
                Have you recompiled your plugin after changing the c4d_symbols.h file?
                • H
                  I have now.  I figured it out about an hour ago.  I was building windows and OS X plugins with different symbols files.  They would work independently but when I tried to put them together they obviously failed.
                  One the DA book.
                  thanks,
                  Ama
