    Setting the format options of an OpenEXR [SOLVED]
    3 Posts 0 Posters 564 Views
      On 11/05/2015 at 09:04, xxxxxxxx wrote:
      I'm trying to automate the setting of the render preferences, but I got stuck at the following.
      I can't seem to find out how to put the openEXR format to "Lossy 16-Bit float, Zip, in blocks of 16 scan lines"
      I found out that you can access the options menu using [c4d.RDATA_SAVEOPTIONS]. But after that i'm at a loss.
      I hope someone can help me.
      Bas
        On 12/05/2015 at 07:39, xxxxxxxx wrote:
        Hello and welcome,
        the documentation does not contain the information on the proper IDs. To set the format settings you have to acess the RDATA_SAVEOPTIONS BaseContainer and add a new subcontainer with the details:
        rd = doc.GetActiveRenderData()
        container = rd.GetData()
        # OpenEXR
        container[c4d.RDATA_FORMAT] = c4d.FILTER_EXR
        saveOptions = container.GetContainerInstance(c4d.RDATA_SAVEOPTIONS)
        # OpenEXR options
        bc = c4d.BaseContainer()
        bc[0] = 3 # ZIP
        bc[1] = True # clamp to half float
        # save OpenEXR options
        saveOptions.SetContainer(0,bc)
        # save render data
        rd.SetData(container)
          On 12/05/2015 at 07:55, xxxxxxxx wrote:
          That is exactly the thing.
          Just started learning python, and like you said, I couldn't find the format settings in the documentation.
          Thanks a million!
