Xpresso Node Position issues
On 12/12/2014 at 10:10, xxxxxxxx wrote:
Is there something more to updating the nodemaster using:
nm.Message(c4d.MSG_UPDATE)
If I create an XPresso setup using python and then copy and past that into a new scene, the placement of the nodes all move back to 0. If I add a node after the creation of the setup the node placements stay put when copying to a new scene. So my guess is there's an update I'm missing?
On 14/12/2014 at 11:10, xxxxxxxx wrote:
could you please post a little snippet how you insert your node master?
Best wishes
Martin -
On 15/12/2014 at 05:26, xxxxxxxx wrote:
as Martin said, can you give us some more information or some simple code that shows how you copy the Xpresso setup? This would help us to answer your question.
Sebastian -
On 15/12/2014 at 09:13, xxxxxxxx wrote:
I made a quick setup for you guys. The problem is if you do not open the XPresso tag after completion and copy the object (CTRL+C, CTRL+V) to a new scene the positions return to 0. If you open up the tag and then copy the object to a new scene the positions are correct.
Here is the (not)working example:
import c4d from c4d import gui #Node Position Issues # Get Object obj = doc.GetActiveObject() # Create Tag tag = c4d.BaseTag(c4d.Texpresso) # Add Tag obj.InsertTag(tag) # Get NodeMaster nm = tag.GetNodeMaster() c4d.EventAdd() # Node Count tcount = 1 # Add Range Mapper Node nRange = nm.CreateNode(nm.GetRoot(),c4d.ID_OPERATOR_RANGEMAPPER,insert=None, x=(100+420), y=(50+(110*tcount))) # Update The NodeMaster nm.Message(c4d.MSG_UPDATE)
On 16/12/2014 at 00:44, xxxxxxxx wrote:
this behavior is actually a bug in Cinema. Thanks for finding this, a bug report was filed.
Sebastian -
On 16/12/2014 at 07:29, xxxxxxxx wrote:
Thanks Sebastian.
