    Watermark & DOF [SOLVED]
    5 Posts 0 Posters 506 Views
      On 15/11/2014 at 19:40, xxxxxxxx wrote:
      Cinema 4D Version:   R13
      Platform:    Mac  ;  Mac OSX  ;
      I've implemented a Video Post plugin that prints information above the render, like a watermark.
      It works pretty well, but when I add DOF to the scene, my watermarks all get blurred. I can see it blurs together with the Back Blur, if I turn back blur off, my watermark keeps intact.
      The native watermark effect works well with DOF, it does not blu. Looks like it's a Video Post as well, so there must be a trick to keep it off DOF blur.
      Things I tried with no success:
      - Set the priority to be very low, like C4DPL_INIT_PRIORITY_PLUGINS-100000, no change
      - Set depth = 0.0 on ExecutePixel on all my watermarked area
        On 17/11/2014 at 02:33, xxxxxxxx wrote:
        in which part of the call sequence are you applying your watermark?
          On 17/11/2014 at 07:17, xxxxxxxx wrote:
          Here...
          RENDERRESULT BDVJData::Execute(BaseVideoPost *node, VideoPostStruct *vps)
          if (vps->vp==VIDEOPOSTCALL_INNER && ! vps->open)
          // watermark
            On 17/11/2014 at 09:22, xxxxxxxx wrote:
            Couldn't you do it, after the frame got rendered?
              On 17/11/2014 at 10:32, xxxxxxxx wrote:
              If i do it after VIDEOPOSTCALL_SUBFRAME or VIDEOPOSTCALL_FRAME the plugin crashes.
              But after VIDEOPOSTCALL_RENDER it works as expected, no bur!
              Thanks!
