    Initializing SplineData CustomGUI
    13 Posts 0 Posters 3.3k Views
      On 27/11/2002 at 14:45, xxxxxxxx wrote:
      I cannot get the ATOM object to work without the "Not Enough Memory" error. Can you forward an example to me of your complete ATOM object example that works? That way I can see if it might be a conflict or something?
      Best Regards,  darf - bhodiNUT
        On 27/11/2002 at 22:12, xxxxxxxx wrote:
        Well, this is just the standard Atom.cpp with the above changes:
            // CINEMA SDK : OBJECT PLUGINS               //
            // VERSION    : CINEMA 4D                  //
            // (c) 1989-2002 MAXON Computer GmbH, all rights reserved  //
            // this example demonstrates how to implement a generator
            // with input objects. the first sub-object (including childs)
            // of the atom is taken as polygonized input. The atom places
            // a sphere at input points and cylinders at input edges.
            // depending on the user options one single mesh or several
            // single objects (hierarchically grouped) are built.
            #include "c4d.h"
            #include "c4d_symbols.h"
            #include "Oatom.h"
            class AtomObject : public ObjectData
            INSTANCEOF(AtomObject, ObjectData);
              virtual BaseObject* GetVirtualObjects(PluginObject *op, HierarchyHelp *hh);
              virtual Bool Message(GeListNode *node, LONG type, void *t_data);
            Bool GetDParameter(GeListNode *node, const DescID &id,GeData &t_data,LONG &flags)
             switch(id[0].id)
             case ATOMOBJECT_PREVIEW:
               PluginMaterial *mat = (PluginMaterial* )node;
               LONG dirty = 0;
               BitmapButtonStruct bbs(static_cast<PluginObject*>(node), id, dirty);
               t_data = GeData(CUSTOMDATATYPE_BITMAPBUTTON,bbs);
               flags |= DESCFLAGS_PARAM_GET;
               break;
             return SUPER::GetDParameter(node, id, t_data, flags);
            Bool SetDParameter(GeListNode *node, const DescID &id, const GeData &t_data, LONG &flags)
             switch(id[0].id)
              flags |= DESCFLAGS_PARAM_SET;
              break;
             return SUPER::SetDParameter(node, id, t_data, flags);
              static NodeData *Alloc(void) { return gNew AtomObject; }
            // initialize settings
            Bool AtomObject::Init(GeListNode *node)
              BaseObject    *op   = (BaseObject* )node;
              BaseContainer *data = op->GetDataInstance();
              AutoAlloc<SplineData> falloffspline;
              if ( !falloffspline ) return FALSE;
              falloffspline->InsertKnot( 0.0, 0.0 );
              falloffspline->InsertKnot( 1.0, 1.0 );
              data->SetData(ATOMOBJECT_SINGLE + 42, GeData(CUSTOMDATATYPE_SPLINE, falloffspline) );
              data->SetReal(ATOMOBJECT_SRAD,5.0);
              data->SetReal(ATOMOBJECT_CRAD,2.0);
              data->SetLong(ATOMOBJECT_SUB,8);
              data->SetBool(ATOMOBJECT_SINGLE,FALSE);
            Bool AtomObject::Message(GeListNode *node, LONG type, void *t_data)
             if (type==MSG_DESCRIPTION_VALIDATE)
              BaseContainer *data = ((BaseObject* )node)->GetDataInstance();
              CutReal(*data,ATOMOBJECT_CRAD,0.0,data->GetReal(ATOMOBJECT_SRAD));
             if (type == MSG_DESCRIPTION_GETBITMAP)
              DescriptionGetBitmap* dgb = static_cast<DescriptionGetBitmap*>(t_data);
              if (dgb->id[0] == ATOMOBJECT_PREVIEW)
               AutoAlloc<BaseBitmap> bm;
               bm->Init(50, 50);
               bm->SetPen(12, 34, 56);
               bm->Line(0, 0, 49, 49);
               dgb->bmp = bm.Release();
            // build a rectangular matrix system with a given normal
            static void RectangularSystem(const Vector &n, Vector *v1, Vector *v2)
             *v2 = Vector(n.y,n.z,n.x);
             *v1 = !((*v2)%n);
             *v2 = !(n%(*v1));
            // build a single polygonal atom object
            static PolygonObject *BuildPolyHull(PolygonObject *op, const Matrix &ml, Real srad, Real crad, LONG sub,
                              Real lod, Neighbor *n, BaseThread *bt)
             BaseContainer bc,cc;
             LONG     spcnt,svcnt,cpcnt,cvcnt,poff,voff,i,j,a,b,side;
             Vector   *spadr=NULL,*cpadr=NULL,*rpadr=NULL,off,pa,pb;
             Polygon  *svadr=NULL,*cvadr=NULL,*rvadr=NULL;
             UVWTag   *suvw =NULL,*cuvw =NULL,*ruvw =NULL;
             Vector   *padr = op->GetPoint();
             Polygon  *vadr = op->GetPolygon();
             LONG     pcnt  = op->GetPointCount();
             LONG   vcnt  = op->GetPolygonCount();
             PolyInfo *pli  = NULL;
             Bool     ok=FALSE;
             Matrix   m;
             // set sphere default values
             bc.SetReal(PRIM_SPHERE_RAD,srad);
             bc.SetReal(PRIM_SPHERE_SUB,sub);
             // set cylinder default values (cylinders are a special case of cone objects)
             cc.SetReal(PRIM_CYLINDER_RADIUS,crad);
             cc.SetReal(PRIM_CYLINDER_HEIGHT,1.0);
             cc.SetLong(PRIM_CYLINDER_CAPS,FALSE);
             cc.SetLong(PRIM_CYLINDER_HSUB,1);
             cc.SetLong(PRIM_CYLINDER_SEG,sub);
             cc.SetReal(PRIM_AXIS,4);
             // generate both primitives
             PolygonObject *sphere=(PolygonObject* )GeneratePrimitive(NULL,Osphere,bc,lod,FALSE,bt),*pp=NULL;
             PolygonObject *cyl=(PolygonObject* )GeneratePrimitive(NULL,Ocylinder,cc,lod,FALSE,bt);
             if (!sphere || !cyl) goto Error;
             spcnt = sphere->GetPointCount();
             svcnt = sphere->GetPolygonCount();
             spadr = sphere->GetPoint();
             svadr = sphere->GetPolygon();
             suvw  = (UVWTag* )sphere->GetTag(Tuvw);
             cpcnt = cyl->GetPointCount();
             cvcnt = cyl->GetPolygonCount();
             cpadr = cyl->GetPoint();
             cvadr = cyl->GetPolygon();
             cuvw  = (UVWTag* )cyl->GetTag(Tuvw);
             // allocate main object
             pp=PolygonObject::Alloc(spcnt*pcnt+cpcnt*n->GetEdgeCount(),svcnt*pcnt+cvcnt*n->GetEdgeCount());
             if (!pp) goto Error;
             // add phong tag
             if (!pp->MakeTag(Tphong)) goto Error;
             // add UVW tag
             ruvw=(UVWTag* )pp->MakeVariableTag(Tuvw,pp->GetPolygonCount());
             if (!ruvw) goto Error;
             // copy sphere geometry for each point
             rpadr = pp->GetPoint();
             rvadr = pp->GetPolygon();
             poff  = 0;
             voff  = 0;
             for (i=0; i<pcnt; i++)
              // test every 256th time if there has been a user break, delete object in this case
              if (!(i&255) && bt && bt->TestBreak()) goto Error;
              off=padr[i]*ml;
              for (j=0; j<spcnt; j++)
               rpadr[poff+j] = off + spadr[j];
              for (j=0; j<svcnt; j++)
               rvadr[voff+j] = Polygon(svadr[j].a+poff,svadr[j].b+poff,svadr[j].c+poff,svadr[j].d+poff);
               ruvw->Cpy(voff+j,suvw,j);
              poff+=spcnt;
              voff+=svcnt;
             // copy cylinder geometry for each edge
             for (i=0; i<vcnt; i++)
              pli = n->GetPolyInfo(i);
              for (side=0; side<4; side++)
               // only proceed if edge has not already been processed
               // and edge really exists (for triangles side 2 from c..d does not exist as c==d)
               if (pli->mark[side] || side==2 && vadr[i].c==vadr[i].d) continue;
               switch (side)
                case 0: a=vadr[i].a; b=vadr[i].b; break;
                case 1: a=vadr[i].b; b=vadr[i].c; break;
                case 2: a=vadr[i].c; b=vadr[i].d; break;
                case 3: a=vadr[i].d; b=vadr[i].a; break;
               // build edge matrix
               pa = padr[a]*ml;
               pb = padr[b]*ml;
               m.off=(pa+pb)*0.5;
               RectangularSystem(!(pb-pa),&m.v1,&m.v2);
               m.v3=pb-pa;
               for (j=0; j<cpcnt; j++)
                rpadr[poff+j] = cpadr[j]*m;
               for (j=0; j<cvcnt; j++)
                rvadr[voff+j] = Polygon(cvadr[j].a+poff,cvadr[j].b+poff,cvadr[j].c+poff,cvadr[j].d+poff);
                ruvw->Cpy(voff+j,cuvw,j);
               poff+=cpcnt;
               voff+=cvcnt;
             // update object as point geometry has changed
             pp->Message(MSG_UPDATE);
             ok=TRUE;
            Error:
             blDelete(sphere);
             blDelete(cyl);
             if (!ok) blDelete(pp);
             return pp;
            // build a single isoparm atom object
            static LineObject *BuildIsoHull(PolygonObject *op, const Matrix &ml, Real srad, Real crad, LONG sub,
             LONG     poff,soff,i,j,a,b,side;
             Vector   *rpadr=NULL,off,pa,pb;
             Segment  *rsadr=NULL;
             Matrix   m;
             Vector   p[8];
             // allocate isoparm object
             LineObject *pp=LineObject::Alloc(8*n->GetEdgeCount(),4*n->GetEdgeCount());
             if (!pp) return NULL;
             rsadr = pp->GetSegment();
             poff  = 0;
             soff  = 0;
             p[0]=Vector(-crad,  0.0,-0.5);
             p[1]=Vector(-crad,  0.0, 0.5);
             p[2]=Vector( crad,  0.0,-0.5);
             p[3]=Vector( crad,  0.0, 0.5);
             p[4]=Vector(  0.0,-crad,-0.5);
             p[5]=Vector(  0.0,-crad, 0.5);
             p[6]=Vector(  0.0, crad,-0.5);
             p[7]=Vector(  0.0, crad, 0.5);
               blDelete(pp);
               return NULL;
               switch (side)
               pa = padr[a]*ml;
               pb = padr[b]*ml;
               m.off=(pa+pb)*0.5;
               m.v3=pb-pa;
               for (j=0; j<8; j++)
                rpadr[poff+j] = p[j]*m;
               for (j=0; j<4; j++)
                rsadr[soff+j].closed = FALSE;
                rsadr[soff+j].cnt    = 2;
               poff+=8;
               soff+=4;
             return pp;
            // go through every (child) object
            static Bool Recurse(HierarchyHelp *hh, BaseThread *bt, BaseObject *main, BaseObject *op, const Matrix &ml, Real srad, Real crad, LONG sub, Bool single)
             // test if input object if polygonal
             if (op->GetType()==Opolygon)
              BaseObject *tp   = NULL;
              Vector     *padr = ToPoly(op)->GetPoint(),pa,pb;
              LONG       pcnt  = ToPoly(op)->GetPointCount(),i,side,a,b;
              Polygon   *vadr = ToPoly(op)->GetPolygon();
              LONG       vcnt  = ToPoly(op)->GetPolygonCount();
              Matrix     m;
              Neighbor  n;
              // load names from resource
              String   pstr = GeLoadString(IDS_ATOM_POINT);
              String   estr = GeLoadString(IDS_ATOM_EDGE);
              // initialize neighbor class
              if (!n.Init(pcnt,vadr,vcnt,NULL)) return FALSE;
              // create separate objects
              // if this option is enabled no polygonal geometry is build - more parametric objects
              // are returned instead
              if (single)
                // alloc sphere primitive
                tp=BaseObject::Alloc(Osphere);
                if (!tp) return FALSE;
                // add phong tag
                if (!tp->MakeTag(Tphong)) return FALSE;
                tp->SetName(pstr+" "+LongToString(i));
                // set object parameters
                BaseContainer *bc = tp->GetDataInstance();
                bc->SetReal(PRIM_SPHERE_RAD,srad);
                bc->SetReal(PRIM_SPHERE_SUB,sub);
                // insert as last object under main
                tp->InsertUnderLast(main);
                // set position in local coordinates
                tp->SetPos(padr[i]*ml);
                // get polygon info for i-th polygon
                pli = n.GetPolyInfo(i);
                 // alloc cylinder primitive
                 tp=BaseObject::Alloc(Ocylinder);
                 // add phong tag
                 switch (side)
                 tp->SetName(estr+" "+LongToString(pli->edge[side]));
                 pa = padr[a]*ml;
                 pb = padr[b]*ml;
                 bc->SetReal(PRIM_CYLINDER_RADIUS,crad);
                 bc->SetReal(PRIM_CYLINDER_HEIGHT,Len(pb-pa));
                 bc->SetReal(PRIM_AXIS,4);
                 bc->SetLong(PRIM_CYLINDER_CAPS,FALSE);
                 bc->SetLong(PRIM_CYLINDER_HSUB,1);
                 bc->SetLong(PRIM_CYLINDER_SEG,sub);
                 // place cylinder at edge center
                 tp->SetPos((pa+pb)*0.5);
                 m.v3=!(pb-pa);
                 RectangularSystem(m.v3,&m.v1,&m.v2);
                 tp->SetRot(MatrixToHPB(m));
              else
               // check if polygonal geometry has to be built
               if (hh->GetVFlags()&VFLAG_POLYGONAL)
                tp = BuildPolyHull(ToPoly(op),ml,srad,crad,sub,hh->GetLOD(),&n,bt);
               else
                tp = PolygonObject::Alloc(0,0);
               if (tp)
                tp->SetName(op->GetName());
                // check if isoparm geometry has to be built
                if (hh->GetVFlags()&VFLAG_ISOPARM)
                 LineObject *ip = BuildIsoHull(ToPoly(op),ml,srad,crad,sub,hh->GetLOD(),&n,bt);
                 // isoparm always needs to be set into a polygon object
                 if (ip) tp->SetIsoparm(ip);
             for (op=op->GetDown(); op; op=op->GetNext())
              if (!Recurse(hh,bt,main,op,ml*op->GetMl(),srad,crad,sub,single)) return FALSE;
             // check for user break
             return !bt || !bt->TestBreak();
            // main routine: build virtual atom objects
            BaseObject *AtomObject::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
             BaseObject *orig = op->GetDown();
             // return if no input object is available
             if (!orig) return NULL;
             // request polygonized input
             hh->AddVFlags(VFLAG_POLYGONAL);
             Bool dirty = FALSE;
             // generate polygonalized clone of input object
             BaseObject *main=NULL,*res=op->GetAndCheckHierarchyClone(hh,orig,HCLONE_ASPOLY,&dirty,FALSE,NULL);
             // if !dirty object is already cached and doesn't need to be rebuilt
             if (!dirty) return res;
             if (!res)   return NULL;
             LONG sub;
             Bool single;
             Real srad,crad;
             // get object container
             BaseContainer *bc=op->GetDataInstance();
             BaseThread    *bt=hh->GetThread();
             // group all further objects with this null object
             main = BaseObject::Alloc(Onull);
             if (!main) goto Error;
             // get object settings
             srad   = bc->GetReal(ATOMOBJECT_SRAD);
             crad   = bc->GetReal(ATOMOBJECT_CRAD);
             sub    = bc->GetLong(ATOMOBJECT_SUB);
             single = bc->GetBool(ATOMOBJECT_SINGLE);
             // go through all child hierarchies
             if (!Recurse(hh,bt,main,res,orig->GetMl(),srad,crad,sub,single)) goto Error;
             blDelete(res);
             return main;
            Error:
             blDelete(res);
             blDelete(main);
             return NULL;
            // be sure to use a unique ID obtained from [www.plugincafe.com](http://www.plugincafe.com)
            #define ID_ATOMOBJECT 1001153
            Bool RegisterAtomObject(void)
             // decide by name if the plugin shall be registered - just for user convenience
             String name=GeLoadString(IDS_ATOM); if (!name.Content()) return TRUE;
             return RegisterObjectPlugin(ID_ATOMOBJECT,name,OBJECT_GENERATOR|OBJECT_INPUT,AtomObject::Alloc,"Oatom","atom.tif","atom_small.tif",0);
          On 28/11/2002 at 08:43, xxxxxxxx wrote:
          I cannot find ATOMOBJECT_PREVIEW in any of the downloadable SDK atom object source or description files. While I would be very interested in that, the obejct still returns a memory error. I am on a Win2000 box with 512mg ram. Can you possibly send the SDK files you created this source for? Still really interested in the ATOMOBJECT_PREVIEW! 🙂
          darf - bhodiNUT
            On 28/11/2002 at 09:26, xxxxxxxx wrote:
            Hey, it's you guys forcing me to always mess up my SDK folder with stupid tests... 🙂
            Please forget ATOMOBJECT_PREVIEW (it's from another forum post showing how to use the bitmap button for previews). Here's a pristine version of RoundedTube.cpp with the spline code in Init() :
                // generator object example (with no input objects)
                #include "c4d.h"
                #include "Oroundedtube.h"
                class RoundedTube : public ObjectData
                    String test;
                    virtual Bool Init   (GeListNode *node);
                    virtual Bool Read   (GeListNode *node, HyperFile *hf, LONG level);
                    virtual Bool Write  (GeListNode *node, HyperFile *hf);
                    virtual void GetDimension   (PluginObject *op, Vector *mp, Vector *rad);
                    virtual Bool Draw           (PluginObject *op, LONG type, BaseDraw *bd, BaseDrawHelp *bh);
                    virtual LONG DetectHandle   (PluginObject *op, BaseDraw *bd, LONG x, LONG y, LONG qualifier);
                    virtual Bool MoveHandle     (PluginObject *op, PluginObject *undo, const Matrix &tm, LONG hit_id, LONG qualifier);
                    static NodeData *Alloc(void) { return gNew RoundedTube; }
                Bool RoundedTube::Message(GeListNode *node, LONG type, void *t_data)
                    CutReal(*data,TUBEOBJECT_IRADX,0.0,data->GetReal(TUBEOBJECT_RAD));
                    CutReal(*data,TUBEOBJECT_ROUNDRAD,0.0,data->GetReal(TUBEOBJECT_IRADX));
                  else if (type==MSG_MENUPREPARE)
                    ((BaseObject* )node)->SetPhong(TRUE,FALSE,0.0);
                void RoundedTube::GetDimension(PluginObject *op, Vector *mp, Vector *rad)
                  Real rado,radx,rady;
                  rado = data->GetReal(TUBEOBJECT_RAD);
                  radx = data->GetReal(TUBEOBJECT_IRADX);
                  rady = data->GetReal(TUBEOBJECT_IRADY);
                  *mp =0.0;
                  switch (data->GetLong(PRIM_AXIS))
                    case 0: case 1: *rad=Vector(rady,rado+radx,rado+radx); break;
                    case 2: case 3: *rad=Vector(rado+radx,rady,rado+radx); break;
                    case 4: case 5: *rad=Vector(rado+radx,rado+radx,rady); break;
                static BaseObject *GenerateLathe(Vector *cpadr, LONG cpcnt, LONG sub, BaseThread *bt)
                  PolygonObject *op=NULL;
                  UVWStruct     us;
                  UVWTag        *tag =NULL;
                  Vector        *padr=NULL;
                  Polygon       *vadr=NULL;
                  LONG          i,j,pcnt,vcnt,a,b,c,d;
                  Real          len=0.0,sn,cs,v1,v2,*uvadr=NULL;
                  pcnt = cpcnt*sub;
                  vcnt = cpcnt*sub;
                  op=PolygonObject::Alloc(pcnt,vcnt);
                  if (!op) goto Error;
                  tag = (UVWTag* )op->MakeVariableTag(Tuvw,vcnt);
                  if (!tag) goto Error;
                  padr=op->GetPoint();
                  vadr=op->GetPolygon();
                  uvadr = (Real* ) GeAlloc(sizeof(Real)*(cpcnt+1));
                  if (!uvadr) goto Error;
                  uvadr[0]=0.0;
                  for (i=0; i<cpcnt; i++)
                    uvadr[i] = len;
                    len+=Len(cpadr[(i+1)%cpcnt]-cpadr[i]);
                  if (len>0.0) len=1.0/len;
                    uvadr[i]*=len;
                  uvadr[cpcnt]=1.0;
                  vcnt=0;
                  for (i=0; i<sub; i++)
                    SinCos(pi2*Real(i)/Real(sub),sn,cs);
                    v1=Real(i  )/Real(sub);
                    v2=Real(i+1)/Real(sub);
                    if (bt && bt->TestBreak()) goto Error;
                      a = cpcnt*i+j;
                      padr[a] = Vector(cpadr[j].x*cs,cpadr[j].y,cpadr[j].x*sn);
                      if (i<sub)
                        b = cpcnt*i          +((j+1)%cpcnt);
                        c = cpcnt*((i+1)%sub)+((j+1)%cpcnt);
                        d = cpcnt*((i+1)%sub)+j;
                        us = UVWStruct(Vector(v1,1.0-uvadr[j],0.0),Vector(v1,1.0-uvadr[j+1],0.0),Vector(v2,1.0-uvadr[j+1],0.0),Vector(v2,1.0-uvadr[j],0.0));
                        tag->Set(vcnt,us);
                        vadr[vcnt++] = Polygon(a,b,c,d);
                  GeFree(uvadr);
                  op->Message(MSG_UPDATE);
                  op->SetPhong(TRUE,TRUE,Rad(80.0));
                  return op;
                Error:
                  GeFree(uvadr);
                  blDelete(op);
                  return NULL;
                static LineObject *GenerateIsoLathe(Vector *cpadr, LONG cpcnt, LONG sub)
                  LONG i;
                  LineObject *op = LineObject::Alloc(cpcnt*4+sub*4,8); if (!op) return NULL;
                  Segment *sadr = op->GetSegment();
                  Vector  *padr=op->GetPoint();
                  for (i=0; i<4; i++)
                    sadr[i].cnt    = cpcnt;
                    sadr[i].closed = TRUE;
                  for (i=0; i<4; i++)
                    sadr[4+i].cnt    = sub;
                    sadr[4+i].closed = TRUE;
                  Real  sn,cs;
                  LONG  j;
                  for (i=0; i<4; i++)
                    SinCos(Real(i)*pi05,sn,cs);
                      padr[i*cpcnt+j] = Vector(cpadr[j].x*cs,cpadr[j].y,cpadr[j].x*sn);
                    SinCos(Real(i)/sub*pi2,sn,cs);
                    for (j=0; j<4; j++)
                      padr[4*cpcnt+j*sub+i] = Vector(cpadr[cpcnt/4*j].x*cs,cpadr[cpcnt/4*j].y,cpadr[cpcnt/4*j].x*sn);
                  return op;
                Bool RoundedTube::Init(GeListNode *node)
                  test = String("Test");
                  data->SetData(TUBEOBJECT_SEG + 42, GeData(CUSTOMDATATYPE_SPLINE, falloffspline) );
                  data->SetReal(TUBEOBJECT_RAD,200.0);
                  data->SetReal(TUBEOBJECT_IRADX,50.0);
                  data->SetReal(TUBEOBJECT_IRADY,50.0);
                  data->SetLong(TUBEOBJECT_SUB,1);
                  data->SetLong(TUBEOBJECT_ROUNDSUB,8);
                  data->SetReal(TUBEOBJECT_ROUNDRAD,10.0);
                  data->SetLong(TUBEOBJECT_SEG,36);
                  data->SetLong(PRIM_AXIS,PRIM_AXIS_YP);
                Bool RoundedTube::Read(GeListNode *node, HyperFile *hf, LONG level)
                  if (level>=0)
                    hf->ReadString(&test);
                Bool RoundedTube::Write(GeListNode *node, HyperFile *hf)
                  hf->WriteString(test);
                static void SetAxis(BaseObject *obj, LONG axis)
                  PointObject *op = ToPoint(obj);
                  if (axis==2) return;
                  LONG    pcnt  = op->GetPointCount(),i;
                  switch (axis)
                    case 0: // +X
                        padr[i] = Vector(padr[i].y,-padr[i].x,padr[i].z);
                      break;
                    case 1: // -X
                        padr[i] = Vector(-padr[i].y,padr[i].x,padr[i].z);
                      break;
                    case 3: // -Y
                        padr[i] = Vector(-padr[i].x,-padr[i].y,padr[i].z);
                      break;
                    case 4: // +Z
                        padr[i] = Vector(padr[i].x,-padr[i].z,padr[i].y);
                      break;
                    case 5: // -Z
                        padr[i] = Vector(padr[i].x,padr[i].z,-padr[i].y);
                      break;
                BaseObject *RoundedTube::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
                  LineObject *lop = NULL;
                  BaseObject *ret = NULL;
                  Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA);
                  if (!dirty) return op->GetCache(hh);
                  Real rad    = data->GetReal(TUBEOBJECT_RAD,200.0);
                  Real iradx  = data->GetReal(TUBEOBJECT_IRADX,50.0);
                  Real irady  = data->GetReal(TUBEOBJECT_IRADY,50.0);
                  Real rrad   = data->GetReal(TUBEOBJECT_ROUNDRAD,10.0);
                  LONG sub    = CalcLOD(data->GetLong(TUBEOBJECT_SUB,1),hh->GetLOD(),1,1000);
                  LONG rsub   = CalcLOD(data->GetLong(TUBEOBJECT_ROUNDSUB,8),hh->GetLOD(),1,1000);
                  LONG seg    = CalcLOD(data->GetLong(TUBEOBJECT_SEG,36),hh->GetLOD(),3,1000);
                  LONG axis   = data->GetLong(PRIM_AXIS);
                  LONG i;
                  Real sn,cs;
                  LONG cpcnt  = 4*(sub+rsub);
                  Vector *cpadr = (Vector* )GeAlloc(cpcnt*sizeof(Vector));
                  if (!cpadr) return NULL;
                    cpadr[i             ]=Vector(rad-iradx,(1.0-Real(i)/Real(sub)*2.0)*(irady-rrad),0.0);
                    cpadr[i+   sub+rsub ]=Vector(rad+(Real(i)/Real(sub)*2.0-1.0)*(iradx-rrad),-irady,0.0);
                    cpadr[i+2*(sub+rsub)]=Vector(rad+iradx,(Real(i)/Real(sub)*2.0-1.0)*(irady-rrad),0.0);
                    cpadr[i+3*(sub+rsub)]=Vector(rad+(1.0-Real(i)/Real(sub)*2.0)*(iradx-rrad),irady,0.0);
                  for (i=0; i<rsub; i++)
                    SinCos(Real(i)/Real(rsub)*pi05,sn,cs);
                    cpadr[i+sub             ]=Vector(rad-(iradx-rrad+cs*rrad),-(irady-rrad+sn*rrad),0.0);
                    cpadr[i+sub+  (sub+rsub)]=Vector(rad+(iradx-rrad+sn*rrad),-(irady-rrad+cs*rrad),0.0);
                    cpadr[i+sub+2*(sub+rsub)]=Vector(rad+(iradx-rrad+cs*rrad),+(irady-rrad+sn*rrad),0.0);
                    cpadr[i+sub+3*(sub+rsub)]=Vector(rad-(iradx-rrad+sn*rrad),+(irady-rrad+cs*rrad),0.0);
                    ret = GenerateLathe(cpadr,cpcnt,seg,hh->GetThread());
                    if (!ret) goto Error;
                    SetAxis(ret,axis);
                    ret->KillTag(Tphong);
                    if (!op->CopyTagsTo(ret,TRUE,FALSE,FALSE,NULL)) goto Error;
                  else
                    ret = PolygonObject::Alloc(0,0);
                  ret->SetName(op->GetName());
                    lop = GenerateIsoLathe(cpadr,cpcnt,seg);
                    if (!lop) goto Error;
                    SetAxis(lop,axis);
                    ret->SetIsoparm(lop);
                  GeFree(cpadr);
                  return ret;
                Error:
                  GeFree(cpadr);
                  blDelete(ret);
                  return NULL;
                static Vector SwapPoint(const Vector &p, LONG axis)
                  switch (axis)
                    case 0: return Vector(p.y,-p.x,p.z); break;
                    case 1: return Vector(-p.y,p.x,p.z); break;
                    case 3: return Vector(-p.x,-p.y,p.z); break;
                    case 4: return Vector(p.x,-p.z,p.y); break;
                    case 5: return Vector(p.x,p.z,-p.y); break;
                  return p;
                static Vector GetRTHandle(PluginObject *op, LONG id)
                  Vector  p;
                  Real    rad    = data->GetReal(TUBEOBJECT_RAD);
                  Real    iradx  = data->GetReal(TUBEOBJECT_IRADX);
                  Real    irady  = data->GetReal(TUBEOBJECT_IRADY);
                  Real    rrad   = data->GetReal(TUBEOBJECT_ROUNDRAD);
                  switch (id)
                    case 0: p=Vector(rad,0.0,0.0); break;
                    case 1: p=Vector(rad+iradx,0.0,0.0); break;
                    case 2: p=Vector(rad,irady,0.0); break;
                    case 3: p=Vector(rad+iradx,irady-rrad,0.0); break;
                    case 4: p=Vector(rad+iradx-rrad,irady,0.0); break;
                  return SwapPoint(p,axis);
                #define HANDLES 5
                Bool RoundedTube::Draw(PluginObject *op, LONG type, BaseDraw *bd, BaseDrawHelp *bh)
                  if (type!=DRAWPASS_HANDLES) return TRUE;
                  LONG    i;
                  Matrix  m      = bh->GetMg();
                  bd->SetPen(GetWorldColor(COLOR_ACTIVEPOINT));
                  for (i=0; i<HANDLES; i++)
                    bd->Handle3D(GetRTHandle(op,i)*m,HANDLE_BIG);
                  bd->Line3D(GetRTHandle(op,0)*m,GetRTHandle(op,1)*m);
                  bd->Line3D(GetRTHandle(op,0)*m,GetRTHandle(op,2)*m);
                  bd->Line3D(GetRTHandle(op,3)*m,SwapPoint(Vector(rad+iradx,irady,0.0),axis)*m);
                  bd->Line3D(GetRTHandle(op,4)*m,SwapPoint(Vector(rad+iradx,irady,0.0),axis)*m);
                LONG RoundedTube::DetectHandle(PluginObject *op, BaseDraw *bd, LONG x, LONG y, LONG qualifier)
                  if (qualifier&QUALIFIER_CTRL) return NOTOK;
                  Matrix  mg = op->GetMg();
                  LONG    i,ret=NOTOK;
                  Vector  p;
                    p = GetRTHandle(op,i);
                    if (bd->PointInRange(p*mg,x,y))
                      ret=i;
                      if (!(qualifier&QUALIFIER_SHIFT)) break;
                  return ret;
                Bool RoundedTube::MoveHandle(PluginObject *op, PluginObject *undo, const Matrix &tm, LONG hit_id, LONG qualifier)
                  BaseContainer *src = undo->GetDataInstance();
                  BaseContainer *dst = op  ->GetDataInstance();
                  Vector handle_dir;
                  switch (hit_id)
                    case 0: handle_dir = Vector( 1.0, 0.0,0.0); break;
                    case 1: handle_dir = Vector( 1.0, 0.0,0.0); break;
                    case 2: handle_dir = Vector( 0.0, 1.0,0.0); break;
                    case 3: handle_dir = Vector( 0.0,-1.0,0.0); break;
                    case 4: handle_dir = Vector(-1.0, 0.0,0.0); break;
                  handle_dir=SwapPoint(handle_dir,src->GetLong(PRIM_AXIS));
                  Real val = tm.off*handle_dir;
                  switch (hit_id)
                    case 0: dst->SetReal(TUBEOBJECT_RAD,FCut(src->GetReal(TUBEOBJECT_RAD)+val,dst->GetReal(TUBEOBJECT_IRADX),MAXRANGE)); break;
                    case 1: dst->SetReal(TUBEOBJECT_IRADX,FCut(src->GetReal(TUBEOBJECT_IRADX)+val,dst->GetReal(TUBEOBJECT_ROUNDRAD),dst->GetReal(TUBEOBJECT_RAD))); break;
                    case 2: dst->SetReal(TUBEOBJECT_IRADY,FCut(src->GetReal(TUBEOBJECT_IRADY)+val,dst->GetReal(TUBEOBJECT_ROUNDRAD),MAXRANGE)); break;
                    case 3: case 4: dst->SetReal(TUBEOBJECT_ROUNDRAD,FCut(src->GetReal(TUBEOBJECT_ROUNDRAD)+val,0.0,FMin(dst->GetReal(TUBEOBJECT_IRADX),dst->GetReal(TUBEOBJECT_IRADY)))); break;
                #define ID_ROUNDEDTUBEOBJECT 1001157
                Bool RegisterRoundedTube(void)
                  String name=GeLoadString(IDS_ROUNDED_TUBE); if (!name.Content()) return TRUE;
                  return RegisterObjectPlugin(ID_ROUNDEDTUBEOBJECT,name,OBJECT_GENERATOR,RoundedTube::Alloc,"Oroundedtube","roundedtube.tif","roundedtube_small.tif",0);
            It works just as fine there. May I ask you to show some of your code that causes the crash? I'd be very interested in reproducing that...
              On 28/11/2002 at 09:29, xxxxxxxx wrote:
              Btw, have you tried any of the other custom data types? I'm wondering if the spline type or the gradient is an exception...
                On 28/11/2002 at 13:31, xxxxxxxx wrote:
                Also, are you sure that  TPMODIFIER_FALLOFF_SPLINE doesn't collide with anything?
                  On 28/11/2002 at 13:39, xxxxxxxx wrote:
                  I took your RoundedTube code and compiled the C4D SDK examples with it. Compiles fine, then, "Not Enough Memory". I removed all other plugins and the error message still happened. Can you send me a .cdl you know works as a test? Are you using WIN2K, VC++6, and C4D v8.012? I need to figure out what is going on here and if it is a bug or an operator error. Thanks for the assistance.
                    On 01/12/2002 at 01:58, xxxxxxxx wrote:
                    This really puzzles me. I have WinXP, VC++6 and C4D 8.012 and no crashes. I've sent you a fresh SDK with the code. I hope it doesn't crash, because otherwise I'm completely lost...
                      On 23/03/2003 at 13:31, xxxxxxxx wrote:
                      several months later , I have the exact same problem !!
                      I dont
                      but  2 of my testers do
                      fo me it works just fine
                      but for them it  gives an out of memory !!!
                      falloffspline->InsertKnot( 0.0, 0.0 );  // this line will cause out of memory
                        On 24/03/2003 at 04:06, xxxxxxxx wrote:
                        I just gave up on this. It would be nice if it worked consistently, blah, blah... 🙂
                        bt
                          On 24/03/2003 at 06:06, xxxxxxxx wrote:
                          Hi there
                          I hope I can help to deconfuse a bit 🙂
                          This is just a little example how to initialize a spline, but it should work similar with every custom data type.
                                GeData d(CUSTOMDATATYPE_SPLINE, DEFAULTVALUE);
                                SplineData* p = (SplineData* )d.GetCustomDataType(CUSTOMDATATYPE_SPLINE);
                                if (p)
                                  p->MakeLinearSpline(2);
                                  p->Flip();
                                your_data_container->SetData(your_id, d);
