    XRef Python command?
    8 Posts 0 Posters 1.3k Views
      On 16/07/2014 at 19:09, xxxxxxxx wrote:
      Anybody know the Python command to XRef a given file?  I can't turn up anything on a google search, using the search on the Python SDK page doesn't give any meaningful results, and going through all of the main topics on that page and doing a search over the page for "xref" doesn't return anything.  Anybody know the python command for this?
        On 16/07/2014 at 19:12, xxxxxxxx wrote:
        This is the only thing I could find that even had "xref" on the page, but that command doesn't seem right...
        http://code.vonc.fr/c4d/python/help/modules/c4d/C4DAtom/GeListNode/index.html?highlight=xref
          On 17/07/2014 at 08:06, xxxxxxxx wrote:
          This creates an empty Xref object in the OM
          c4d.CallCommand(1025766)
          These are the Xref menu ID#s found in: C:\Program Files\MAXON\Your_C4D_version\resource\res\menus\c4d_m_editor.res
          Put the numbers in a CallCommand to execute them.
          Example: c4d.CallCommand(1025763)
          SUBMENU IDS_MENU_XREF
              PLUGIN_CMD_1025763;
              SEPARATOR;
              PLUGIN_CMD_1025766;
              PLUGIN_CMD_1025776;
              PLUGIN_CMD_1025773;
              PLUGIN_CMD_200000162;
              PLUGIN_CMD_200000163;
            On 17/07/2014 at 15:39, xxxxxxxx wrote:
            So XRef is a plugin, not a native C4D command??
              On 17/07/2014 at 16:48, xxxxxxxx wrote:
              Practically everything in C4D is a plugin.
              When Maxon adds new things it's usually done with a plugin.
              If you use the FindPlugin() function you can see them all. It's a pretty long list of plugins.
              All a command really does is execute the proper plugin.
                On 17/07/2014 at 18:46, xxxxxxxx wrote:
                Hrm, any idea of how to actually get to the commands being used by the plugin, or where those scripts are at?  If I just give CallCommand the plugin ID, it just opens up the dialog, which is what I was trying to avoid.  Same thing with Save Selected Objects As.  I was thinking that it would just be similar to a normal file save command, where you just pass it the filename, but no dice.
                  On 17/07/2014 at 19:03, xxxxxxxx wrote:
                  The IDs for it are here:
                  C:\Program Files\MAXON\YOUR_C4D_VERSION\resource\modules\ca\res\description\dxrefmanager.h
                  C:\Program Files\MAXON\YOUR_C4D_VERSION\resource\modules\ca\res\description\oxrefholder.h
                  C:\Program Files\MAXON\YOUR_C4D_VERSION\resource\modules\ca\res\description\oxref.h
                  I personally never use xrefs.
                  So I don't really know how much that can be done with them.
                    On 18/07/2014 at 12:01, xxxxxxxx wrote:
                    Hmmm, it looks like the code for the XRef plugin is in :
                    C:\Program Files\MAXON\CINEMA 4D R15\resource\modules\ca\characteranim.cdl64
                    Which seems to be an encrypted file, so you can't see what the actual XRef commands are.  😞
                    And I'm assuming the "Save Selected Object As" is set up the same way.  This makes me a sad panda.
