    extract separat objects from Polgon-selction-tags
    Scheduled Pinned Locked Moved Plugin Requests
    5 Posts 0 Posters 1.3k Views
      On 27/05/2014 at 05:19, xxxxxxxx wrote:
      Hi There,
      I'm looking for a script like that:
      Is there still a possibility to extract separat objects from Polgon-selction-tags of
      a imported Object, witch contains many of those Polygon-selection-tags?
      It have been a multi-hierarchy-object but this structure is collapsed in to one object.
      Any one an idea? 🙂
      It would be very nice to get a script or any thing else for those issues.
      Thx
        On 28/05/2014 at 03:06, xxxxxxxx wrote:
        Try this in the Script Manager (select your Polygon Object) :
        is_polyselection = lambda x: x.CheckType(c4d.Tpolygonselection)
            if not op or not op.CheckType(c4d.Opolygon) :
                c4d.gui.MessageDialog('Please select a Polygon Object')
            selections = filter(is_polyselection, op.GetTags())
            if not selections:
            result = []
            points = op.GetAllPoints()
            polys = op.GetAllPolygons()
            for tag in selections:
                sel = tag.GetBaseSelect()
                new_polys = []
                for i, v in enumerate(sel.GetAll(len(polys))) :
                    if not v:
                        continue
                    new_polys.append(polys[i])
                obj = c4d.PolygonObject(len(points), len(new_polys))
                obj.SetAllPoints(points)
                for i, p in enumerate(new_polys) :
                    obj.SetPolygon(i, p)
                obj.SetName('%s - %s' % (op.GetName(), tag.GetName()))
                c4d.utils.SendModelingCommand(c4d.MCOMMAND_OPTIMIZE, [obj])
                result.append(obj)
            root = None
            if len(result) == 1:
                root = result[0]
                root = c4d.BaseObject(c4d.Onull)
                root.SetName(op.GetName())
                for obj in result:
                    obj.InsertUnderLast(root)
            doc.StartUndo()
            doc.InsertObject(root)
            doc.AddUndo(c4d.UNDOTYPE_NEW, root)
            doc.EndUndo()
        Note that it uses the Optimize Command to remove the points it will not need.
        -Niklas
          On 29/05/2014 at 04:57, xxxxxxxx wrote:
          Jihaaaaaa!!!! It works!
          I put in your Code in to the Pythonconsole and the result was fine.
          Thanks for that amazing script.
          (Is there still a chance to tune it up with a extra feature to center axis of all the new Objects?)
          PS: von wo aus aus BRD kommst du? Die Brücke kommt mir bekannt vor. 🙂 **** **** ****
            On 29/05/2014 at 06:01, xxxxxxxx wrote:
            Ahh sorry, now I see...
            it have to be necessary to optimize/kill all the needless points before.
            After that I can center the axes. This I can make in one shot for multible objects.
            (I have to think before I write) 🙂
            regards from Cologne
              On 30/05/2014 at 09:40, xxxxxxxx wrote:
              You're welcome.
              I'm from Bavaria 🙂 But the Sidney Harbour Bridge is surely anything but near your location 😉
              -Niklas
