    FBX Export parameters
    7 Posts 0 Posters 732 Views
      On 23/04/2014 at 07:49, xxxxxxxx wrote:
      Cinema 4D Version:   R15.057
      Hello guys. It's my first time posting 🙂
      I'm playing around with C++ scripting for c4d and now I'm trying to export an FBX in this way
      \> String fbx_filepath = "HARDCODED_PATH.fbx";
      \> Bool saved = SaveDocument(doc, fbx_filepath, SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, fbx_plugin_id);
      It exported the file and saved it correctly, but take the parameters from last manual export on the export option in c4d.
      Can I set these options from my script? can I get all the options available for this exporter?
      EDIT:
      It seems not to be take in consideration the parameters passed through SetWorldPluginData. Any ideas?
      PS: Sorry for my caveman english.
        On 28/04/2014 at 06:10, xxxxxxxx wrote:
        I'm Getting the plugin settings with:  GetWorldPluginData and trying to save those with  SetWorldPluginData but is not working.
        Any ideas?
          On 28/04/2014 at 07:28, xxxxxxxx wrote:
          I'm not sure if I understand your question.
          But this is an example of using .fbx export that works fine for me in R13:
          //To get/set an exporter settings we have to send a MSG_RETRIEVEPRIVATEDATA message to the exporter
          //We can then access and change the exporter settings retrieving its container instance
          //Here's an example of how to setup an FBX export in C++:
          #include "..\..\..\..\resource\modules\fbx\res\description\Ffbxexport.h"
          BaseList2D *exporter;
          BasePlugin *plug = FindPlugin(1026370, PLUGINTYPE_SCENESAVER);
          if (plug && plug->Message(MSG_RETRIEVEPRIVATEDATA, &exporter))
            BaseContainer *data = exporter->GetDataInstance();
            data->SetLong(FBXEXPORT_ASCII, FALSE);
            data->SetLong(FBXEXPORT_BAKE_ALL_FRAMES, FALSE);
            data->SetLong(FBXEXPORT_SAVE_NORMALS, TRUE);
            data->SetLong(FBXEXPORT_ANIMATION, TRUE);
            data->SetLong(FBXEXPORT_TEXTURES, TRUE);
            data->SetLong(FBXEXPORT_EMBED_TEXTURES, TRUE);
            SaveDocument(doc, "C:\\model.fbx", SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, 1026370);
            On 28/04/2014 at 08:08, xxxxxxxx wrote:
            Instead of SetLong for R15 I must call SetInt32 but It work.
            I was trying to do the same using GetWorldPluginData and SetWorldPluginData. I can retrieve the parameters but I can't set them.
            Thank you very much.
              On 28/04/2014 at 09:46, xxxxxxxx wrote:
              I can't tell from your answer.
              Is it working OK for you now. Or are you still having problems?
                On 28/04/2014 at 10:18, xxxxxxxx wrote:
                Now it's working! Thanks to you.
                My previous attempt:
                	BaseContainer* bc = GetWorldPluginData(FBX_PLUGIN_ID);
                	Bool saved = false;
                	if (bc != NULL)
                		bc->SetInt32(FBXEXPORT_SAVE_NORMALS, 1);
                		saved = SetWorldPluginData(FBX_PLUGIN_ID, *bc, false);
                	if (saved)
                		GePrint("PARAMETERS SET CORRECTLY");
                	else
                		GePrint("PARAMETERS NOT SET");
                	saved = SaveDocument(doc, fbx_filepath, SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, FBX_PLUGIN_ID);
                  On 07/05/2014 at 12:59, xxxxxxxx wrote:
                  Now I'm exporting an FBX from my plugin.
                  When I'm trying to export Textures using the exporter I noticed that textures are exported only if "Embed textures" is checked. This behavior happen using the plugin from file->export->fbx and using the SaveDocument invocation from my plugin.
                  Any ideas to fix it?
