Making Spline Mask Editable
On 01/11/2013 at 10:44, xxxxxxxx wrote:
I'm running this in a generator object.
I want to make the Spline Mask editable so I can do more to it, however it returns an empty spline object.
import c4d from c4d.utils.noise import C4DNoise def MakeEditable(op) : if (not op) | op.CheckType(c4d.Opolygon) | op.CheckType(c4d.Ospline) : return op op = [op.GetClone()] doc = c4d.documents.BaseDocument() doc.InsertObject(op[0],None,None) op = c4d.utils.SendModelingCommand( command = c4d.MCOMMAND_MAKEEDITABLE, list = op, mode = c4d.MODELINGCOMMANDMODE_EDGESELECTION, doc = doc ) return op[0] def main() : obj = c4d.BaseObject(c4d.Osplinetext) objMask = c4d.BaseObject(1019396) #Spline Mask obj[c4d.PRIM_TEXT_TEXT] = "Test" objTemp1 = MakeEditable(obj) objTemp1[c4d.SPLINEOBJECT_INTERPOLATION] = 4 objTemp1[c4d.SPLINEOBJECT_ANGLE] = 90 objTemp1[c4d.SPLINEOBJECT_MAXIMUMLENGTH] = 25 objTemp1.InsertUnder(objMask) obj3 = MakeEditable(objMask) #This line seems to kill it... obj3.Message (c4d.MSG_UPDATE) c4d.EventAdd() return obj3 #return objMask #this works when it hasn't been make editable yet
Any hints as to what I'm missing would be wonderful. Thanks so much,
Chris Schmdit
On 01/11/2013 at 11:06, xxxxxxxx wrote:
Hi Chris,
I can reproduce your problem and reported to the developers. There'll be an answer soon. One note on
your code though: Do not call c4d.EventAdd() from a Python Generator or Tag, only from commands (aka
scripts). It is 1. completely redundant and 2. can lead to an infinite unbreakable refresh of your scene.Best,
-Niklas -
On 02/11/2013 at 15:30, xxxxxxxx wrote:
@ CHris,
print obj3 did give me <c4d.SplineObject object called 'Spline Mask/Spline' with ID 5101 at 0x0E541620> so it is working
adding doc.InsertObject(obj3) will insert an edited spline
You can use obj3 as global variable to use in another function.
import c4d from c4d.utils.noise import C4DNoise def MakeEditable(op) : if (not op) | op.CheckType(c4d.Opolygon) | op.CheckType(c4d.Ospline) : return op op = [op.GetClone()] doc = c4d.documents.BaseDocument() doc.InsertObject(op[0],None,None) op = c4d.utils.SendModelingCommand( command = c4d.MCOMMAND_MAKEEDITABLE, list = op, mode = c4d.MODELINGCOMMANDMODE_EDGESELECTION, doc = doc ) return op[0] def ReturnObj3() : global obj3 #declaring this variable as global will make it available in other functions obj = c4d.BaseObject(c4d.Osplinetext) objMask = c4d.BaseObject(1019396) #Spline Mask obj[c4d.PRIM_TEXT_TEXT] = "Test" objTemp1 = MakeEditable(obj) objTemp1[c4d.SPLINEOBJECT_INTERPOLATION] = 4 objTemp1[c4d.SPLINEOBJECT_ANGLE] = 90 objTemp1[c4d.SPLINEOBJECT_MAXIMUMLENGTH] = 25 objTemp1.InsertUnder(objMask) obj3 = MakeEditable(objMask) obj3.Message (c4d.MSG_UPDATE) c4d.EventAdd() def main() : ReturnObj3() print obj3 if __name__=='__main__': main()
Hope this help
On 04/11/2013 at 12:24, xxxxxxxx wrote:
Thanks for the replies guys!
I solved that problem with a connect object instead of a spline mask before I saw the post from Focus3D. I have another question to follow up though.
I've simplified the code as much as I can. If I remove a point, and update the number of points in the spline the generator is still returning a phantom point.
Insert this code into a Python Generator, make it editable, select all the points and move them. There is a 'point' that can't be selected. Stuck here... any help would be killer.
import c4d import math from c4d.utils.noise import C4DNoise #Welcome to the world of Python def MakeEditable(op) : if (not op) | op.CheckType(c4d.Opolygon) | op.CheckType(c4d.Ospline) : return op op = [op.GetClone()] doc = c4d.documents.BaseDocument() doc.InsertObject(op[0],None,None) op = c4d.utils.SendModelingCommand( command = c4d.MCOMMAND_MAKEEDITABLE, list = op, mode = c4d.MODELINGCOMMANDMODE_EDGESELECTION, doc = doc ) return op[0] def main() : obj = c4d.BaseObject(c4d.Osplinetext) obj[c4d.PRIM_TEXT_TEXT] = "S" obj2 = MakeEditable(obj) obj2[c4d.SPLINEOBJECT_TYPE] = 0 #lin basePoints = obj2.GetAllPoints() pointCount = obj2.GetPointCount() pointList1 = [] count3 = 0 while (count3 < pointCount) : if(count3 != 0) : print "Point ", count3, basePoints[count3]," added" newPoint = basePoints[count3] pointList1.append(newPoint) count3 += 1 print len(pointList1) obj2.ResizeObject(len(pointList1)) obj2.SetAllPoints(pointList1) obj2.Message (c4d.MSG_UPDATE) return obj2
Thanks again!
On 04/11/2013 at 13:09, xxxxxxxx wrote:
Well I seem to have gotten around that by initiating a new spline object. Would still be curious why the first example didn't work though...
obj3 = c4d.SplineObject(len(pointList1), c4d.SPLINETYPE_LINEAR) obj3[c4d.SPLINEOBJECT_CLOSED] = True obj3.SetAllPoints(pointList1) obj3.Message (c4d.MSG_UPDATE) return obj3
On 05/11/2013 at 16:30, xxxxxxxx wrote:
@Chris,
Which version of Cinema4D are you using?
I tried your first code with c4d R13.061 with the Python Generator and it is working.
try to close and restart cinema 4d. -
On 06/11/2013 at 10:07, xxxxxxxx wrote:
I'm currently tinkering in R14
On 06/11/2013 at 17:53, xxxxxxxx wrote:
@Chris,
for R14, you are right it is not working but if you use command = c4d.MCOMMAND_CURRENTSTATETOOBJECT instead of command = c4d.MCOMMAND_MAKEEDITABLE, it will work.
Also try to use myDoc=c4d.documents.GetActiveDocument().Hope this will help.
On 08/11/2013 at 11:45, xxxxxxxx wrote:
Thanks Focus, learning little by little.
