    Load DLL in plugin?
    3 Posts 0 Posters 358 Views
      On 19/05/2013 at 02:46, xxxxxxxx wrote:
      Cinema 4D Version:   R13+
      Anybody know of the best way to load a dll from within a plugin (Command plugin in this case)?  There are no facilities in the SDK so it would either need to be platform specific or it might be made independent using Qt or some other library, one that supports dll loading/unloading, statically built into the plugin.
        On 19/05/2013 at 05:34, xxxxxxxx wrote:
        <ADDRESS>
        Mac OSX  ;
        Language(s) :
        C++  ;
        </ADDRESS> Anybody know of the best way to load a dll from within a plugin (Command plugin in this case)?  There are no facilities in the SDK so it would either need to be platform specific or it might be made independent using Qt or some other library, one that supports dll loading/unloading, statically built into the plugin.
        On the PC use:
        dll_handle = LoadLibrary( path );
        (Have a look at MS docs for error codes).
        On OS X (/Linux) use
                  handle = dlopen( path, mode );               // RTLD_LOCAL: The loaded images exported symbols are generally hidden. They are available only to dlsym invocations that use the handle returned by this function
                  error_message = dlerror();
                  if ( error_message )
                       GeDebugOut("OS error at dlopen %s", error_message );
        (See man page or OS X docs for possible values of <mode> and error codes).
        Best regards,
        Wilfried
          On 19/05/2013 at 08:08, xxxxxxxx wrote:
          Alright.  It looks like I will be going the platform-independent support way.
          Thanks!
