    filename object
    4 Posts 0 Posters 431 Views
      On 08/04/2013 at 05:46, xxxxxxxx wrote:
      Hey Guys,
      I have a problem with the Filename object - i can't find it.
      i have this entry in .res:
            FILENAME SERVERPATH {DIRECTORY;}
      I would like to initialize it like so:
            self.InitAttr(op, c4d.Filename, [c4d.SERVERPATH])
      But apparently Filename doesn't exist.
      How do i initialize a 'Filename' object?
      Any help is appreciated!
      Aurel
        On 08/04/2013 at 05:54, xxxxxxxx wrote:
        There is no filename object in Python. In dialogs, there is Get/SetFilename(). You could try
        to use SetFilename() on your objects container to initialize the attribute. I can not garuantee
        that it will work, but it may be a try worth.
        data = op.GetDataInstance()
        data.SetFilename(c4d.MYOBJECTPLUGIN_SERVERPATH, "")
        Please see the following post about naming conventions why I prefixed the SERVERPATH name.
        Best
        -Niklas
          On 08/04/2013 at 06:10, xxxxxxxx wrote:
          try string as type. if string does not work, you cannot use the filename customgui.
          many custom guis require a certain datatype class which has to be wrapped for
          python. the custom data types which have been wrapped for python can all be
          found under c4d.CustomDataType.
          the same goes basically for the gui itself. if the customgui class is not wrapped
          for python you might be not able to retrieve the desired data from the gui element,
          as the class and therefore the interface/methods are missing.
          c4d.Filename does obviously not work, because it is a type you just made up.
            On 10/04/2013 at 00:09, xxxxxxxx wrote:
            Hey,
            Thanks for the answers! I tried NiklasR's idea, and it works like a charm 😉 thanks!
