    Adding/Removing UserData from PlugingTag
    6 Posts 0 Posters 633 Views
      On 09/02/2013 at 17:59, xxxxxxxx wrote:
      Hi all,
      Ive got a Plugin-tag and Id like to add or remove userdatas. Adding works, but removing is a problem. I have already tried out various things, but nothing has worked. Here are some naked lines. Which command do I need to update the userdatacontainer immediately?
      import os
      import math
      import sys
      from c4d import plugins, utils, bitmaps, gui
      # be sure to use a unique ID obtained from www.plugincafe.com
      PLUGIN_ID = 145268788 #TestID
      class TagPlugin(plugins.TagData) :
        def Init(self, node) :
        def Message(self, node, type, data) :
            if type==c4d.MSG_DESCRIPTION_COMMAND:
                if data["id"][0].id == 10001: self.AddUD(node)
                elif data["id"][0].id == 10002: self.RemoveUD(node)
        def Execute(self, tag, doc, op, bt, priority, flags) :#
            return c4d.EXECUTIONRESULT_OK
        def AddUD(self, node) :
            data = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BOOL)
            data[c4d.DESC_NAME] = "Enable"
            node[node.AddUserData(data)] = False
        def RemoveUD(self,node) :
            node.RemoveUserData(1)
        bmp = bitmaps.BaseBitmap()
        bmp.InitWith(os.path.join(dir, "res", "icon.tif"))
        plugins.RegisterTagPlugin(id=PLUGIN_ID,
                                 str="TagPlugin",
                                 g=TagPlugin,
                                 description="TagPlugin",
                                 icon=bmp,
                                 info=c4d.TAG_MULTIPLE|c4d.TAG_EXPRESSION|c4d.TAG_VISIBLE)
      Another problem Ive got are separators. For example:
            data = c4d.GetCustomDatatypeDefault(c4d.DTYPE_SEPARATOR)
            data[c4d.DESC_SEPARATORLINE] = True
            data[c4d.DESC_NAME] = "Enable2"
      The separators are listed in the UserDataManager but hidden in the interface. I wasn´t able to get a solution. What is wrong?
      Thanks in anticipation
      rown
        On 09/02/2013 at 18:47, xxxxxxxx wrote:
        I ran into this same annoying problem trying to remove UD using C++.
        Apparently the whole tag has to be updated when removing UD. But not when adding them.
        Try this:
          c4d.SendCoreMessage(c4d.COREMSG_CINEMA, c4d.BaseContainer(c4d.COREMSG_CINEMA_FORCE_AM_UPDATE))
        This is currently not documented in any of the SDK's. But it should be.
          On 10/02/2013 at 04:08, xxxxxxxx wrote:
          Hello Scott,
          the command seems to be brutal, but works perfectly. Thank you very much.
          One last little question: Do you happen to know the separator-problem, too?
          Greetings
          rown
            On 10/02/2013 at 07:53, xxxxxxxx wrote:
            Sorry. I can't help with the separator problem.
            That's a strange one.
              On 10/02/2013 at 15:53, xxxxxxxx wrote:
              With some persistence I managed to figure it out.
              def addSeparator(obj) :
                if obj is None: return
                bc = c4d.GetCustomDatatypeDefault(c4d.DTYPE_SEPARATOR) #Create default container
                bc[c4d.DESC_NAME] = "My Separator"                     #Rename the entry
                bc.SetLong(c4d.DESC_CUSTOMGUI,c4d.DTYPE_SEPARATOR)
                bc.SetBool(c4d.DESC_SEPARATORLINE, False)
                obj.AddUserData(bc)                                    #Add the userdata container
                c4d.EventAdd()                                         #Update C4D
              Again.
              Things like this really should be documented better.
                On 11/02/2013 at 02:39, xxxxxxxx wrote:
                Wow, thank you very much. I'm very excited. Will try tonight.
                Greeting
                rown
