    ComboBox child with icons in .res based dialog
    7 Posts 0 Posters 912 Views 1 Watching
      On 04/12/2012 at 18:59, xxxxxxxx wrote:
      Hi again guys..
      I know how to get an icon loaded for a child item of a combobox when using GeDialog:
      self.AddComboBox(prof_combo, c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, inith=20)
      self.AddChild(prof_combo,prof_circle,"Circle&i"+str(c4d.OBJECT_SPLINECIRCLE) + "&")
      self.AddChild(prof_combo,prof_square,"Square&i"+str(c4d.OBJECT_SPLINERECTANGLE) + "&")
      but I can't figure out how to get the same behavior using a .res dialog file:
      COMBOBOX prof_combo
                ALIGN_TOP; ALIGN_LEFT; SIZE 150, 0;
                CHILDS
                  0, PROF_CIRCLE;
                  1, PROF_SQUARE;
                  2, PROF_NSIDE;
                  3, PROF_STAR;
                  4, PROF_FLOWER;
                  5, PROF_CUSTOM;
      whats the right way of doing it ?
        On 05/12/2012 at 01:50, xxxxxxxx wrote:
        Hi Massimiliano,
        The declaration of the COMBOBOX seems correct in your .res for the dialog.
        Are prof_combo (should be renamed as ID_PROF_COMBO according to CINEMA naming convention), PROF_CIRCLE, PROF_SQUARE etc. (should be renamed to IDS_PROF_CIRCLE, IDS_PROF_SQUARE etc.) declared in c4d_symbols.h?
        And do you define the strings identifiers in a .str in strings_xx/dialogs?
          On 05/12/2012 at 04:18, xxxxxxxx wrote:
          Hi Yannick,
          yep sorry, I stripped out all the other lines just to focus on the combo. The dialog works good in both cases, I got all the resources from ResEdit, so all the IDS are declared in c4d_symbols.h and strings. I just can't get the same icons in .res based dialog:
          geDialog version:
          res_based:
          The dialogs are for two separate things, I'm not mixing 'em up, just trying to recreate the same(ish) dialog based on .res. Hope this will clear up things a bit better 🙂
          cheers
            On 05/12/2012 at 05:32, xxxxxxxx wrote:
            How do you define the strings in the .str file?
            They should include the icon ID literal value (not the ID name i.e. c4d.OBJECT_SPLINECIRCLE and c4d.OBJECT_SPLINERECTANGLE) :
            IDS_CIRCLE "Circle&i5181&";
            IDS_SQUARE "Square&i5186&";
              On 05/12/2012 at 06:08, xxxxxxxx wrote:
              Ahhh, ok, I see. I have to set the icon ID in the strings, not the dialog.res 🙂
              That's not exactly obvious (for noobs like me), maybe the SDK should repor it..for GeDialogs.AddChild() too, as icons are not even mentioned 🙂
              Thanks for your help an time !
                On 05/12/2012 at 10:16, xxxxxxxx wrote:
                Tricks, fwiw, you have a typo in your gui. I know it's not your priority in this post, but I thought I'd just give you a heads up.
                Jim
                  On 05/12/2012 at 10:32, xxxxxxxx wrote:
                  Ouch, thanks 🙂 I hate that "th"
