    Import multiple AI Splines
    Scheduled Pinned Locked Moved Plugin Requests
    3 Posts 0 Posters 981 Views
      On 13/11/2012 at 15:35, xxxxxxxx wrote:
      Hi I'm new to the Forum,
      looking for a script / plugin that will could import 1000 ai files (splines) into a single C4D project file / and or a way of sequencing them a timeline like Flash / Ae would.
      Any ideas would be appreciated. Otherwise will have to do manually.
      Want to start learning python when I get some free time...
      Cheers!
      Dan
        On 13/11/2012 at 16:00, xxxxxxxx wrote:
        If the splines are numbered and ai vers 8 or lower ( so Cinema can read them)
        you can use the "Xref_xPLAY" preset found in the SteadyBAKE tools found
        at my site : www.tcastudios.com -> files.
        A more manual option is to drag them all in from within the Content Browser.
        Then you can use a simpler expression to only show/activate the spline corresponding
        to the frame you need.
        Lennart
          On 14/11/2012 at 16:01, xxxxxxxx wrote:
          Brilliant. Got it working... Thanks Lennart your a star!
