    Edge Selection indices
    5 Posts 0 Posters 478 Views
      On 09/11/2012 at 01:32, xxxxxxxx wrote:
      Cinema 4D Version:
      I have a question about what the edge index of a selection represents with respect to either a triangular or quadrangular polygon?
      "Edges are indexed (4*poly)+edge where edge is from 0-3."
      If poly is a triangle and edge 2 is considered, is the edge from poly.c->poly.a or does it always represent poly.c->poly.a?  Here is my code.  Please help me validate that it is correctly considering the vertex indices represented by each edge:
              LONG    pi, ei;
            for (LONG seg = 0L; bs->GetRange(seg,&a,&b); ++seg)
                for (i=a; i<=b; ++i)
                    pi =    i/4L;
                    ei =    Mod(i,4L);
                    if        (ei == 0L)
                        DetermineAsSourceVertex(verts, normal, polys[pi].a, side, mepsilon);
                        DetermineAsSourceVertex(verts, normal, polys[pi].b, side, mepsilon);
                    else if (ei == 1L)
                        DetermineAsSourceVertex(verts, normal, polys[pi].c, side, mepsilon);
                    else if (ei == 2L)
                        if (polys[pi].c != polys[pi].d)
                            DetermineAsSourceVertex(verts, normal, polys[pi].d, side, mepsilon);
                        else
                    else // ei == 3L
        On 09/11/2012 at 03:55, xxxxxxxx wrote:
        Yes, that looks right to me. I have made the same assumptions in my plugins.
        /Filip
          On 20/11/2012 at 10:43, xxxxxxxx wrote:
          I just woke up and haven't had me coffee yet but... are you sure that side 2 is used at all if it's a triangle?  I may be crossing some info about one thing with another, but IIRC, side 2 is typically not used/indicated if it's a triangle, which would allow you to skip a test (not a big deal, either way).
            On 21/11/2012 at 05:45, xxxxxxxx wrote:
            Edge 3 (for 0-3 indices) would be omitted and skipped for a triangle.
              On 21/11/2012 at 08:39, xxxxxxxx wrote:
              My reference was from the PolyInfo structure, where you find this in the SDK docs...
              `.... S N I P ....
                for (i=0; i<polygon_count; i++)
                pli = n->GetPolyInfo(i);
                for (side=0; side<4; side++) // test all 4 sides of a polygon
                  // only proceed if edge has not already been processed
                  // and edge really exists (***** for triangles side 2 from c..d does not exist as c==d ****** )
                  if (pli->mark[side] || side==2 && vadr[i].c==vadr[i].d) continue;
                  // one can also skip the side==2 && vadr[i].c==vadr[i].d test as pli->mark[2] is always TRUE for triangles
                  switch (side)
                    case 0: a=vadr[i].a; b=vadr[i].b; break;
                    case 1: a=vadr[i].b; b=vadr[i].c; break;
                    case 2: a=vadr[i].c; b=vadr[i].d; break;
                    case 3: a=vadr[i].d; b=vadr[i].a; break;
                  // do something with the edge a..b
              0-1-2-3 are the indices for a-b/b-c/c-d/d-a. For triangles the face/edge index 2 is set to NOTOK (as c == d). e.g. a value of 5-8-2-1 for 'face' means: a-b neighbor face is 5, b-c neighbor face is 8 etc.
              .... S N I P ....
              ...it seems to me that all references to edges (and/or edge numbering) would follow the same logic - since the c-d edge doesn't exist for triangles, it would/should not be listed/indicated.
