SNHook not working
On 03/11/2012 at 17:37, xxxxxxxx wrote:
Cinema 4D Version: R14
Platform: Windows ;
Language(s) : C++ ;---------
Hey Guys,I want to protect my plugin so I use the SNHook.
Cinema ask for serial, all fine. But if the serial is wrong and i click cancel, the plugin is still loaded?!?I tried it at R13 and my mate in R14. What do I wrong?
//-----------------------------------------------------------------------------------------------------------------------------------------------------------// LONG RoomMakerSNHook::SNCheck(const String &c4dsn,const String &sn,LONG regdate,LONG curdate) //-----------------------------------------------------------------------------------------------------------------------------------------------------------// { return SN_WRONGNUMBER; }case C4DPL_INIT_SYS: if (!resource.Init()) return FALSE; // don't start plugin without resource // serial hook example; if used must be registered before PluginStart(), best in C4DPL_INIT_SYS if (!RegisterExampleSNHook()) return FALSE;Nothing, it still load my objectData !?
On 04/11/2012 at 01:29, xxxxxxxx wrote:
Returning FALSE from PluginMessage() when C4DPL_INIT_SYS is sent does not prevent Cinema to call PluginStart(). Ask your SNHook subclass instance if it registration was successful.
-Niklas
On 04/11/2012 at 03:51, xxxxxxxx wrote:
My Subclass?
On 04/11/2012 at 05:33, xxxxxxxx wrote:
RoomMakerSNHook is your subclass of the SNHook class, isn't it?
LONG RoomMakerSNHook::SNCheck(const String &c4dsn,const String &sn,LONG regdate,LONG curdate) { Bool registration_successful = FALSE; /* ... */ this->success = registration_successful; if (!registration_successful) return SN_WRONGNUMBER; else return SN_OKAY; } Bool RoomMakerSNHook::Success() { return this->success; } /* ... */ RoomMakerSNHook snhook; Bool PluginStart() { if (!snhook->Success()) return TRUE; /* Register your plugins. */ } Bool PluginMessage(LONG id, void* ptr) { switch (id) { case C4DPL_INIT_SYS: /* Register SNHook and etc. */ break; } return TRUE; }That's how I was doin' it. Maybe I missed something obvious. But it works.
On 05/11/2012 at 01:11, xxxxxxxx wrote:
All right. Thank you.
