    description INCLUDE with housemade descriptions
    4 Posts 0 Posters 326 Views
      On 07/08/2012 at 01:37, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      I am creating several Object plugins that all use (partially) the same description-elements. I have created an extra description-set that I want to include in my other descriptions (just like Oprimitiveaxis is included in most primitives).
      But when I do INCLUDE Onrprimitivebase; I get an error on this line. The description works when put directly on an object, so there should be no error in it.
      CONTAINER Onrprimitivebase {
        NAME Onrprimitivebase;
        INCLUDE Obase;
        GROUP ID_OBJECTPROPERTIES {
            LONG PRIM_NR_USEGMENTS   { MIN 1; };
            LONG PRIM_NR_VSEGMENTS   { MIN 1; };
      STRINGTABLE Onrprimitivebase {
        PRIM_NR_USEGMENTS   "U Segments";
        PRIM_NR_VSEGMENTS   "V Segments";
      #ifndef _Onrprimitivebase_H_
      #define _Onrprimitivebase_H_
        enum {
            PRIM_NR_USEGMENTS = 3001,
            PRIM_NR_VSEGMENTS,
            __PRIM_NR_DUMMY__
      #endif // _Onrprimitivebase_H_
      And this is the description where I want to include it:
      CONTAINER Onrpillow {
        NAME Onrpillow;
        INCLUDE Obase;
            REAL PRIM_NRPILLOW_WIDTH       { UNIT METER; MIN 0; }
            REAL PRIM_NRPILLOW_HEIGHT      { UNIT METER; MIN 0; }
            REAL PRIM_NRPILLOW_DEPTH       { UNIT METER; MIN 0; }
            BOOL PRIM_NRPILLOW_INVNORMALS  { };
        INCLUDE Onrprimitivebase;        // <-- Error
      STRINGTABLE Onrpillow {
        Onrpillow           "Pillow Object";
        PRIM_NRPILLOW_WIDTH      "Width";
        PRIM_NRPILLOW_HEIGHT     "Height";
        PRIM_NRPILLOW_DEPTH      "Depth";
        PRIM_NRPILLOW_USEGMENTS  "U Segments";
        PRIM_NRPILLOW_VSEGMENTS  "V Segments";
        PRIM_NRPILLOW_INVNORMALS "Inverse Normals";
      #ifndef _Onrpillow_H_
      #define _Onrpillow_H_
        enum {
            Onrpillow = 1028945,
            PRIM_NRPILLOW_WIDTH = 1001,
            PRIM_NRPILLOW_HEIGHT,
            PRIM_NRPILLOW_DEPTH,
            PRIM_NRPILLOW_INVNORMALS,
            __PRIM_NRPILLOW_DUMMY__
      #endif // _Onrpillow_H_
      How can I include my own descriptions? Doing INCLUDE Oprimitiveaxis; works, for instance.
      Thanks in advance,
      Niklas
        On 07/08/2012 at 05:34, xxxxxxxx wrote:
        I just found this statement in the SDK where the INCLUDE flag is described: _The parent description must have been registered with CINEMA 4D before this description is registered for the lookup to work.
        _ Does that mean I have to register an (maybe invisible) plugin that uses this description before I can INCLUDE it? _
        _-Niklas _
        _
          On 07/08/2012 at 06:27, xxxxxxxx wrote:
          _
          Yes, there's the RegisterDescription() function in the C++ SDK especially designed for that. You can call this function with your included description before registering the main plugin using it.
            On 07/08/2012 at 06:44, xxxxxxxx wrote:
            Thanks. I wasn't watching out for this function as I'm currently working on a Python plugin. The RegisterDescription() function is not available in Python. I have registered a dummy object-plugin, not elegant, but it works.
            -N
