SelectionChanger problems
On 25/04/2012 at 11:37, xxxxxxxx wrote:
Cinema 4D Version: 12
Platform: Windows ;
Language(s) : C++ ;---------
I normally convert between edges, polygons, and points using the SMC version of the convert tool.
I just found this SelectionChanger helper class in the SDK. But I can't seem to make it work.
It doesn't do anything when I run it:BaseObject *obj = doc->GetActiveObject(); if(!obj)return FALSE; PolygonObject *pobj = ToPoly(obj); BaseSelect *sel = pobj->GetPointS(); SelectionChanger *sc = SelectionChanger::Alloc(); sc->InitFromSelection(sel, Mpoints, pobj); sc->GetEdgeS(); //<--Does not select any edges from my selected points!? pobj->Message(MSG_UPDATE); EventAdd();
What am I doing wrong?
On 25/04/2012 at 16:15, xxxxxxxx wrote:
Never mind. I think I've got it figured out.
Apparently this class "returns" the points, edges, and polygons. But it doesn't actually "select" them.Here's an example of using this class to select edges based on the selected points. Just in case anyone else needs it:
#include "..\..\..\..\resource\_api\c4d_libs\lib_selectionchanger.h" BaseObject *obj = doc->GetActiveObject(); if(!obj)return FALSE; PolygonObject *pobj = ToPoly(obj); //Cast the active object to a polygon object type BaseSelect *sel = pobj->GetPointS(); //Get the currently selected points of the object BaseSelect *esel = pobj->GetEdgeS(); //Get the currently selected edges(this will probably be zero) SelectionChanger *sc = SelectionChanger::Alloc(); //Create an instance of the SelectionChanger class sc->InitFromSelection(sel, Mpoints, pobj); //Initialize it with the selected points and the object BaseSelect *newsel = sc->GetEdgeS(); //Store the selected edges (based on selected points) in a BaseSelect CallCommand(16351); //Switch to Edges mode newsel->CopyTo(esel); //Make the edges selected on the object in the scene pobj->Message(MSG_UPDATE); //Update the changes SelectionChanger::Free(sc); //Free the memory used in Alloc
