    Variable with float value is nil
    5 Posts 0 Posters 451 Views
      On 31/01/2012 at 07:14, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Platform:    Mac  ;  Mac OSX  ;
      Try the following:
      main(doc,op)
      var temp=10.0;
      println(temp==nil);
      I get a 1, saying that it is a nil.
      But if you modify the first line to:
      var temp=10;
      It returns 0, saying it is not a nil.
      This is a bug, right?
        On 31/01/2012 at 07:20, xxxxxxxx wrote:
        I have a parsing function that parses for numbers, strings and variables. It works just fine except if it parses a floating point number. Because, when I try to check if it found a legitimate value (it is!!!) so that I could use it, with:
        if(value!=nil) ...
        It returns me a nil because it can't see that it is a numerical floating point value.
        This is ruining my code that was previosly working just fine (in release 11.5).
          On 31/01/2012 at 14:10, xxxxxxxx wrote:
          Now it really looks like a bug.
          If I change the code to:
          main(doc,op)
          var t=10.1;
          println(t==nil);
          It will print out 0, as expected.
          It is only when the float is equal to its integer (as in, 1.0 or 10.0 ou -2.0) that the test for nil returns true.
            On 31/01/2012 at 15:40, xxxxxxxx wrote:
            I can also confirm that nil doesn't seem to work when the decimal value is .0.
            Can you use this as an alternative to nil in your projects Rui?:
            main(doc,op)
            var t=10.0;
            if(t!=null)println(t);
              On 31/01/2012 at 15:57, xxxxxxxx wrote:
              Yes, with null it seems to be working.
              Anyway, I already reported it to Maxon.
              Thank you, Scott 🙂
