    Switching off scene ambient occlusion
    16 Posts 0 Posters 1.9k Views
      On 16/11/2011 at 04:56, xxxxxxxx wrote:
      Yes, GetType is documented. But I hadn't expect it do differ on VideoPost data, too.
      I had to print the Video Post type and search it in all the header files.
      Maybe you wanna try this one next time. 🙂
        rdata = doc.GetActiveRenderData()
        post  = rdata.GetFirstVideoPost()
        t = post.GetType()
        for k, v in c4d.__dict__.iteritems() :
            if v == t:
                print "Maybe you are searching for `" + k + "` ?"
      Maybe you are searching for `VPambientocclusion` ?
        On 16/11/2011 at 06:34, xxxxxxxx wrote:
        Thank you very much, it works. This will become a real time saver 🙂
          All these enums should be documented to avoid searching in files.
          Welcome to my world.😉
          It's refreshing to hear someone in a moderator role say the same thing.
            On 08/03/2012 at 07:40, xxxxxxxx wrote:
            Hi there,
            I also try to disable AO. So I read the topic and messed around for some hours to get it work. but the following script That I copied from this thread is not working under 13.051.
            If it is a simple mistake ... sorry for that I am a newbee. But I have no Idea what to do next:(
            Thanks, Jops
                # Get render data
                if rdata == None: return
                # Get first Video Post effect
                if post == None: return
                # Loop through Video Post effects
                while post:
                    if post.GetType() == c4d.VPambientocclusion:
                        print "DETECTED"
                        post[c4d.VPAMBIENTOCCLUSION_APPLYTOSCENE] = True
                        #post.SetBit(c4d.BIT_ACTIVE)   # also not working
                        post = None
                        print "else"
                        post = post.GetNext()
              On 08/03/2012 at 08:39, xxxxxxxx wrote:
              Hello Jops,
              This line will turn this checkmark on!
              If you want to disable it, change the value to False.
                         post[c4d.VPAMBIENTOCCLUSION_APPLYTOSCENE] = False
              Niklas
                On 08/03/2012 at 09:04, xxxxxxxx wrote:
                Hello Niklas,
                ahh wenn wron bool then 😞
                I would love to be able to read-out and activate this bool here:
                any chances?
                thanks a lot
                Jops
                  On 08/03/2012 at 11:45, xxxxxxxx wrote:
                  Hi Jops,
                  I digged a bit through the SDK and found out that you can use post.SetBit(c4d.BIT_VPDISABLED) and post.DelBit(c4d.BIT_VPDISABLED) to either disable or enable the video-post. Note that, as the constant is called VP_DISABLED, setting the bit will disable the video-post, deleting the bit will enable it. Confusing, if you ask me 😉
                  Also note, that your call to c4d.EventAdd() before post = None is redundant, as you call it at the and of main() anyway..
                  # Disables the Ambient Occlusion Video-post from the Render Manager
                    if not rdata:
                    pdata = rdata.GetFirstVideoPost()
                    if not pdata:
                    while pdata:
                        if pdata.CheckType(c4d.VPambientocclusion) :
                            pdata.DelBit(c4d.BIT_VPDISABLED)
                            pdata = None
                            pdata = pdata.GetNext()
                  -Niklas
                    On 09/03/2012 at 01:39, xxxxxxxx wrote:
                    Hi Niklas,
                    Thanks a lot for you great advice. I will imideately test it out.
                    did you find it in the Python SDK (that would mean that I did not look hard enough :()
                    best wishes
                    Jops
                      On 09/03/2012 at 03:21, xxxxxxxx wrote:
                      Hi Jops,
                      I knew about the use of BaseList2D.SetBit() and ~.GetBit() before. After searching some minutes they appeared in my mind. Looking at their documentation made me spot the VP_DISABLED constant, and it all made sense. 😉
                      I think, understanding the documentation and knowing what to search for requires a lot of experience, you don't have to shame.
                      -Niklas
                        On 09/03/2012 at 03:39, xxxxxxxx wrote:
                        Thank you...
                        I try hard and for quite a while to get into it, but it takes a lot of time especially if you have no friend or college who already knows his stuff 🙂
                        CU
                        Jops
                          On 09/03/2012 at 06:11, xxxxxxxx wrote:
                          Just to let you know, if you're in a hurry getting into the Py4D SDK: I'm currently giving private education especially belonging to the Py4D SDK to someone from Utah, America.
                          -Niklas
                            On 09/03/2012 at 06:27, xxxxxxxx wrote:
                            niklas du hast eine PM.
