    Changing Material's Icon?
    4 Posts 0 Posters 379 Views
      On 01/06/2011 at 10:14, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Language(s) :   C.O.F.F.E.E  ;    PYTHON  ;
      I've tried everything I can think of. But I can't figure out how to change the icon previews on materials.
      I started with the basics:
      var mat = doc->GetActiveMaterial();
      mat#MatPreviewFlat2D = true; //<---invalid ID
      Then I tried getting at them from the material's container:
      var bc = mat->GetContainer();
      var preview = bc->SetData(MatPreviewFlat2D, true);//<--- member not found
      bc->SetContainer(preview);
      Then I thought maybe that they weren't held by the material.
      But held by another object(ID_MATERIAL_PREVIEW) inside of the material:
      //No errors...But it doesn't do anything
      var preview = mat#ID_MATERIAL_PREVIEW;
      preview = MatPreviewFlat2D;
      CallCommand(12252); // Render Materials updates the ICON
      Nope.
      Can anyone tell me what I'm doing wrong?
      If it's not possible in Coffee. Then a Python or C++ solution is ok.
      *Edit:
      After more looking. I found a preview class in the C++ SDK.
      It has a SetPreviewType(MatPreviewType t) method in it.
      But I could not find these in the Python and Coffee SDK's. So does that mean that this is only supported in C++?
        On 02/06/2011 at 17:16, xxxxxxxx wrote:
        Am I even close with this?
        Or am I way off?
        Bool SimplePlugin::Execute(BaseDocument *doc)
          BaseMaterial *mat = doc->GetActiveMaterial();
          Bool Init(BaseMaterial* mat, LONG lCount);
          MaterialPreviewData *MPD = What the heck goes here?
          MPD->SetPreviewType(MatPreviewFlat2D);
          On 06/06/2011 at 06:28, xxxxxxxx wrote:
          It's possible through C++, probably Python too. The material preview is a custom data type which are not supported by COFFEE.
          Example:
          #include "customgui_matpreview.h"
          Bool MenuTest::Execute(BaseDocument *doc)
            if (!mat) return FALSE;
            GeData d;
            if (mat->GetParameter(DescLevel(MATERIAL_PREVIEW), d, DESCFLAGS_GET_0))
                MaterialPreviewData *mp = (MaterialPreviewData* )d.GetCustomDataType(CUSTOMDATATYPE_MATPREVIEW);
                // set the preview type, see the C++ docs
                if (mp) mp->SetPreviewType(MatPreviewTorus);
                mat->SetParameter(DescLevel(MATERIAL_PREVIEW), d, DESCFLAGS_SET_0);
            mat->Message(MSG_UPDATE);
            mat->Update(TRUE, FALSE);
            EventAdd();
            On 06/06/2011 at 07:54, xxxxxxxx wrote:
            Thanks.
            I was trying out every combination of GeData and SetParameter() I could think of over the weekend. But I just couldn't find the magic combination to make it work.
            The SDK also confused me a lot. Because under "customgui_matpreview.h" it says that it must be created with Alloc. And then there's three different types of Init() functions.
            I know now that those functions are for different things than setting the built-in preview types. But the whole experience was extremely confusing to me.
            I hope the C++ SDK gets some sort of attention in the future. And a more clear way of explaining things to newer users is found. This C++ stuff is actually pretty easy to do when it's explained.
            If I can be of any help in that area. Please let me know. I'm willing to volunteer some time to that.
            Thanks again for the help,
