    Point & Poly Select Functions
    PYTHON Development
    0
    1.2k
    • H
      On 01/04/2011 at 01:59, xxxxxxxx wrote:
      I was hoping to get some advice on how to properly use the following functions that are part of c4d.BaseSelect()
      Snippets that don't work as I would expect
          #Select all points and polys
          point_select.SelectAll(0, point_count)
          poly_select.SelectAll(0, poly_count)
      My Full Source Code
      Select All Polygons
      Open Source - Free for all
      Originally written by:
          Donovan Keith
          [email protected]
      Last Edit: 04/01/2011
      from c4d import gui, documents
          #Get active document
          if not doc:
              gui.MessageDialog("No active document.")
              return False
          #Get first active object
          op = doc.GetActiveObject()
          if not op or not op.CheckType(c4d.Opolygon) :
              gui.MessageDialog("No poly objected selected")
              return False
          #Get point and polygon selections and counts
          point_select = op.GetPointS()
          poly_select = op.GetPolygonS()
          point_count = op.GetPointCount()
          poly_count = op.GetPolygonCount()
          #Alert C4D something has changed
      What am I doing incorrectly? I can properly select and deselect elements using .Select() and .Deselect(), but no joy otherwise.
      Donovan
      • H
        On 01/04/2011 at 03:11, xxxxxxxx wrote:
        Hi, did you upgrade to R12.043? There are some fixes in BaseSelect. Cheers, Sebastian
        • H
          On 01/04/2011 at 17:36, xxxxxxxx wrote:
          Hi Sebastian,
          Yes, I'm running 12.043. Does my script as posted above select all points and polygons for you, as it does nothing here?
          Donovan
          • H
            On 01/04/2011 at 17:53, xxxxxxxx wrote:
            Your script seems to be alright.
            Alternatively, you can use this:
            def SelectAll(bs,max) :
                for i in range(max) : bs.Select(i)
            Cheers, nux
            • H
              On 20/05/2011 at 14:18, xxxxxxxx wrote:
              Okay, for whatever reason the bs.SelectAll(min,max) function is not working for me, but bs.Select(i) is. Thanks nux95!
              • H
                On 20/05/2011 at 15:01, xxxxxxxx wrote:
                bs.ToggleAll() isn't working for me either. Odd. Can anyone else confirm that these functions aren't working? Or is it something to do with my installation?
                • H
                  On 01/06/2011 at 09:32, xxxxxxxx wrote:
                  @Donovan: What is wrong with ToggleAll? It works fine here (r12.043).
