    Popup desctiption
    3 Posts 0 Posters 321 Views
      On 09/12/2010 at 08:47, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Hello all,
      i am trying to create a popup description (CUSTOMGUI_POPUP) in GetDDescription of tagdata.
      i can create popup but i can't find the way to add the element inside popup.
      any help ?
      Franz
        On 14/12/2010 at 03:26, xxxxxxxx wrote:
        You have to react to the MSG_DESCRIPTION_POPUP message to fill the menu structure.
        Here is a simple example of a popup menu with a sub-menu and some separators.
        Bool MorphMixerObject::Message(GeListNode *node, LONG type, void *data)
          if (type==MSG_DESCRIPTION_POPUP)
              DescriptionPopup *dp = (DescriptionPopup* )data;
              if (dp->id[0]==MORPHMIXER_PRESET)
                  if (dp->chosen==0)    //fill menu
                      dp->popup.InsData(MORPHMIXER_PRESET+1,"hello");
                      dp->popup.InsData(MORPHMIXER_PRESET+2,"world");
                      dp->popup.InsData(0,String());    //separator
                      BaseContainer child;    //sub-container for sub-menu
                      child.InsData(MORPHMIXER_PRESET+3,"CINEMA 4D");
                      child.InsData(0,String());    //separator
                      child.InsData(MORPHMIXER_PRESET+4,"BodyPaint 3D");
                      child.InsData(1,"Sub-Menu");    //sub-menu name
                      dp->popup.InsData(0,child);        //insert sub-menu
                      child.FlushAll();
                  else    //menu item was chosen
                      GePrint(LongToString(dp->chosen));
        Bool MorphMixerObject::GetDDescription(GeListNode *node, Description *description,DESCFLAGS_DESC &flags)
          if (!description->LoadDescription(node->GetType())) return FALSE;
          // important to check for speedup c4d!
          const DescID *singleid = description->GetSingleDescID();
          LONG index = MORPHMIXER_PRESET;
          BaseContainer bc2;
          DescID cid = DescLevel(index,DTYPE_POPUP,0);
          if (!singleid || cid.IsPartOf(*singleid,NULL)) // important to check for speedup c4d!
              bc2 = GetCustomDataTypeDefault(DTYPE_POPUP);
              bc2.SetLong(DESC_CUSTOMGUI,CUSTOMGUI_POPUP);
              bc2.SetLong(DESC_ANIMATE,DESC_ANIMATE_OFF);
              bc2.SetBool(DESC_REMOVEABLE,FALSE);
              bc2.SetString(DESC_NAME,"Preset");
              bc2.SetString(DESC_SHORT_NAME,"Preset");
              if (!description->SetParameter(cid,bc2,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
          return SUPER::GetDDescription(node,description,flags);
          On 14/12/2010 at 08:03, xxxxxxxx wrote:
          thans ... very useful
          Franz
