    point coordinates of joint animated object
    11 Posts 0 Posters 958 Views
      On 30/06/2010 at 02:04, xxxxxxxx wrote:
      How do you access the deformed mesh? Usally you have to perform a Current State To Object to obtain the deformed mesh.
        On 30/06/2010 at 02:18, xxxxxxxx wrote:
        I am using this:
        //get the linked object
        BaseObject* baseMesh = ToPoly((PolygonObject* )(bc->GetLink(BASEMESH,doc)));
        PolygonObject* cloneOfBase = NULL;
        if (baseMesh->GetType()==Opolygon || baseMesh->GetType()==Opoint)
        cloneOfBase = static_cast<PolygonObject*>(baseMesh->GetClone(0, NULL));
        else
        cloneOfBase = op->GetAndCheckHierarchyClone(hh,baseMesh,HCLONE_ASPOLY,&dirty,NULL,FALSE);
        Ello
          On 30/06/2010 at 03:48, xxxxxxxx wrote:
          You can't simply use the PolygonObject. You must first perform a Current State To Object. This is done with SendModelingCommand(). GetAndCheckHierarchyClone() on the other hand should take care of it when the linke dobject is not a polygon object. Does it work if the linked object is not a polygon object and deformed by a deformer?
            On 30/06/2010 at 03:59, xxxxxxxx wrote:
            yes, it works.. but with joints you need to have a polygon object. so i need to use currentstate to object.. i'll try it out
            thank you  for the hint
            ello
              On 30/06/2010 at 11:45, xxxxxxxx wrote:
              Hi, I got it working. However, i have now a memory leak and i dont know what i need to free?
              Using  MCOMMAND_CURRENTSTATETOOBJECT returns an AtomArray and the SDK tells me that i need to free it afterwards. GeFree seems not to work here..
              thanks for your input..
              Ello
                On 30/06/2010 at 21:38, xxxxxxxx wrote:
                AtomArray::Free(array);
                  On 30/06/2010 at 21:55, xxxxxxxx wrote:
                  thank you. it already worked, there did just another leak pop up due to the change i made 🙂
                    On 02/07/2010 at 23:19, xxxxxxxx wrote:
                    Another similar problem occurs when i clone objects that are animated by joints.
                    how can  i clone objects which are animated by joints and apply positions and rotations to them??
                    do i need to use MCOMMAND_CURRENTSTATETOOBJECT in this case, too? this could get performance hungry for a bunch of clones...
                    thanks for any further input.
                    ello
                      On 07/07/2010 at 03:47, xxxxxxxx wrote:
                      Yes, you need to use MCOMMAND_CURRENTSTATETOOBJECT in this case too. Whenever you need to access the deformed mesh you have to use MCOMMAND_CURRENTSTATETOOBJECT, at least in cases where you can't be sure that all caches are build. This is the case in GetVirtualObjects().
                        On 07/07/2010 at 03:49, xxxxxxxx wrote:
                        thank you for the info. i am quite curious how this will affect the performance
                        ello
