    ContantBrowser Path Q
    5 Posts 0 Posters 608 Views
      On 03/03/2010 at 06:18, xxxxxxxx wrote:
      Cinema 4D Version:   R11+
      Hoy, Hopefully a simple problem here:)
      Atm I load objects into my scene from a folder on the computer.
      However I'd like to load from the ContentBrowser.
      If I make a "hard" path I get the object such as:
      path->SetFullString("preset://SteadyCAMPRO303.lib4d/SCPROv303");
      everything work fine.
      But to follow the safe, platform independent way I'm trying to set a correct path,
      such as:
      var path;
      var loaddocname = "NameOfObject";
      // Look in UserPrefs -> Browser
      println("Search User Browser");
      path = GeGetStartupWritePath();
      path->AddLast("library");             if(!GeFileExist(path,TRUE)) {println("User Library folder not found");return;}
      path->AddLast("browser");             if(!GeFileExist(path,TRUE)) {println("User Browser folder not found");return;}
         // path->AddLast("preset://");             if(!GeFileExist(path,TRUE)) {println("User Preset folder not found");return;}
      path->AddLast("steadycampro303");
      path->SetSuffix("lib4d");              if(!GeFileExist(path,TRUE)) {println("User steadycampro303.lib4d not found");return;}
      path->AddLast(loaddocname);
      but get an error that the lib file is not found.
      I suppose the "preset://" part ( out commented here) is the culprit?
      How to access the :// part in the path?
      Lennart
        On 15/03/2010 at 08:05, xxxxxxxx wrote:
        Am I thinking wrong here?
        Or can I use the hard links as within a regular browser?
        Lennart
          On 17/03/2010 at 00:48, xxxxxxxx wrote:
          I am afraid you have to use Filename->SetFullString() in this case.
            On 17/03/2010 at 05:09, xxxxxxxx wrote:
            Thanks, I see.
            I don't have a Window machine to try with, how would the following
            be written so it get's correct in Windows?
            Lennart
              This should be ok. Windows accepts forward slashs. Just make if you use backslashs in strings you have to use double backslashs for each single backslash.
              for example
              println("c:\\test.c4d");
              prints
              c:	est.c4d
