    Assigning a material to a material tag
    3 Posts 0 Posters 389 Views
      On 30/12/2007 at 15:54, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:      Mac OSX  ;
      I want to create and assign a material in COFFEE, but this line generates an error:
      > tag- >SetMaterial(material);
      In the COFFEE doc, I found that the SetMaterial methods wants a MARKER. What is that and how can I transform a material into a marker?
      This is my code for creating & assigning a material in COFFEE:
      > _
      >      // getting the selected object
      >      if (!(obj = doc->GetActiveObject())) return;
      >      // creating a new material and a new texture tag
      >      if (!(material = AllocMaterial(Mmaterial))) { println("Error: AllocMaterial"); }
      >      if (!(tag = AllocTag(Ttexture))) { println("Error: AllocTag"); }
      >      // assigning the texture tag to the object
      >      if( !(obj->InsertTag(tag))) { println("Error: InsertTag"); }
      >      // insering the new material to the document
      >      if (!(doc->InsertMaterial(material, NULL))) { println("Error: InsertMaterial"); }
      >      // assigning the material to the texture tag
      >      tag->SetMaterial(material);
      >      // enabling the Color channel for the material
      >      material->SetChannelState(CHANNEL_COLOR, TRUE);
      >      // getting the path for the texture
      >      file = GeGetRootFilename();
      >      if (!file) return;
      >      file->RemoveLast();
      >      file->AddLast("tex.jpg");
      >      // assigning the texture to the Color channel
      >      if (!(channel = material->GetChannel(CHANNEL_COLOR))) { println("Error: GetChannel"); }
      >      if (!(container = channel->GetContainer())) { println("Error: GetContainer"); }
      >      container->SetData(CH_TEXTURE, file->GetFullString());
      >      channel->SetContainer(container);
      > _
      Thanks for your help!!
        On 31/12/2007 at 03:37, xxxxxxxx wrote:
        This works for me:
        > var mat = AllocMaterial(Mmaterial);
        > doc- >InsertMaterial(mat, NULL);
        > mat->SetName("Hello Material");
        > var tag = AllocTag(Ttexture);
        > op->InsertTag(tag);
        > var bc = tag->GetContainer();
        > bc->SetData(TEXTURETAG_MATERIAL , mat);
        > tag->SetContainer(bc);
          On 31/12/2007 at 05:29, xxxxxxxx wrote:
          Ah, you extract the container from the tag, modify it and write it back. OK, I'll try it out.
