    Command MCOMMAND_MAKEEDITABLE
    SDK Help
    0
    • H
      On 28/05/2007 at 08:36, xxxxxxxx wrote:
      Cinema 4D Version:   R10
      In order to export objects I need to convert them into polygon objects before exporting.
      But there are some problems with the hierarchy.
      The ->GetNext and ->GetDown functions dont work as soon as a new object has been inserted.
      How can I fix this?
      And I have seen the Polygonize function, but I cant use it.
      Any help is appreciated.
      static bool transform(BaseObject* op, BaseDocument* dst)
           if(!op || !dst )
                return 1;
           ModelingCommandData cd;
           if(op->GetType() >= Ocube && op->GetType() <= Osinglepoly)
                cd.doc = dst;
                cd.op = op;
                if (!SendModelingCommand(MCOMMAND_MAKEEDITABLE,cd))goto Error;
                if (!cd.result) goto Error;
                BaseObject* res = (BaseObject* )cd.result->GetIndex(0);
                if (!res) goto Error;
                dst->InsertObject(res, NULL, NULL);
           transform(op->GetDown(), dst);
           transform(op->GetNext(), dst);
           return 0;
           Error:
           GePrint("Fehler bei Objektumwandlung");
           AtomArray::Free(cd.result);
           return 1;
      //Jedes mathematische Objekt wird in ein Polygonobjekt umgewandelt
      static BaseDocument* TransformObjToPoly(BaseDocument* doc)
           BaseDocument* dst=BaseDocument::Alloc(); if (!dst) return NULL;
           BaseObject* nx=NULL;
           BaseObject* res=NULL;
           BaseObject* op=NULL;
           cd.doc = dst;
           if (!doc->CopyTo(dst,0,NULL)) goto Error;
           if(transform(dst->GetFirstObject(), dst)) goto Error;
           return dst;
      Error:
           blDelete(dst);
           return NULL;
      • H
        On 29/05/2007 at 00:43, xxxxxxxx wrote:
        Hi ...
        What you want to do is to make all the objects in the document editable. Am I right?
        I use this code segment for that.
        Bool dlgLevelControl::Command(LONG id, const BaseContainer &msg;)
        switch(id)
        case BTN_TEST://when the testing button is pressed
        BaseDocument *doc=GetActiveDocument();
        BaseObject *obj=doc->GetFirstObject();
        MakeAllEditable(obj);
        break;
        void dlgTest::MakeAllEditable(BaseObject *obj)
             String strObj;
             if(obj)
                  strObj=obj->GetName();
                  ModelingCommandData mcd;
                  mcd.bc=obj->GetDataInstance();
                  mcd.doc=doc;
                  mcd.op=obj;
                  mcd.mode=MODIFY_ALL;
                  mcd.flags=MODELINGCOMMANDFLAG_CREATEUNDO;
                  if (!SendModelingCommand(MCOMMAND_MAKEEDITABLE,mcd)) return;
                  EventAdd(EVENT_FORCEREDRAW);
                  obj=doc->SearchObject(strObj);
                  MakeAllEditable(obj->GetDown());
                  MakeAllEditable(obj->GetNext());
        Hope it can help ...
        Zaw Min Tun
        • H
          On 29/05/2007 at 01:17, xxxxxxxx wrote:
          Thank you very much, it works perfectly.
          Since the changes rearanges objects in the list, this
          was necessary to go to modified object.
          It drove me nuts for a while 🙂
          tnx again.
          • H
            On 31/05/2007 at 19:29, xxxxxxxx wrote:
            Yes ... it's always like that ... 🙂
            You're welcome ...
            Zaw Min Tun
