    MaterialData, CalcTransparency, CalcAlpha
    2 Posts 0 Posters 234 Views
      On 22/05/2007 at 01:23, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      How to use those methods:
      virtual void CalcTransparency(PluginMaterial* mat, VolumeData* vd);
      virtual void CalcAlpha(PluginMaterial* mat, VolumeData* vd);
      even if i set information about what my plugin requires from the raytracer, like this:
      LONG ParticleVolume::GetRenderInfo(PluginMaterial *mat)
           return SHADER_TRANSPARENCY|SHADER_VOLUMETRIC|SHADER_ALPHA;
      program never enter to this method. Only CalcVolumetric and CalSurface work.
      It is easy to check with ParticleVolume from sdk.
      Just write
           GePrint("CalcTransprarency"); in ParticleVolume::CalcTransparency <--- it never apper in console window.
        On 22/05/2007 at 02:17, xxxxxxxx wrote:
        it will be called, but you the shaded objects have to be in a shadowed area. check this example file with the ParticleVolume example from the SDk. CalcTransparency will be called.
        example file
        trans.c4d
