    Can't recieve data from my shader plugin
    SDK Help
    0
    • H
      On 20/04/2007 at 01:56, xxxxxxxx wrote:
      Cinema 4D Version:   R9-R10
      Language(s) :   C.O.F.F.E.E  ;  C++  ;
      COFFEE RELATED
      Hi there!
      I've created a volumeplugin and applied it to an object, but when i'm trying to access it via
      <CODE>var doc = GetActiveDocument();
      var textag = op->GetFirstTag();
      while(textag!NULL)
      if(textag->GetType() == Ttexture)
            var mat = textag#TEXTURETAG_MATERIAL;
            println("FOUND IT: ", mat);
      textag = textag->GetNext();
      }</CODE>
      the console always prints "nil" for my shader, but if i'm doing the same with a standard C4d material anything is going fine.
      Did i missing something?
      Ciao
      Sascha
      • H
        On 20/04/2007 at 03:24, xxxxxxxx wrote:
        Without knowing the sourcecode of your volumeshader it is a bit hard to say what is going on. In what language is the shader written, COFFEE or C++? The C++ SDK Volume shaders work fine for your little example. You can contact me under sdk_support(at)maxon.net if you want to keep your source code confidential.
        • H
          On 20/04/2007 at 04:06, xxxxxxxx wrote:
          Hi Matthias,
          it is nothing special, just a simple dummy shader, mainly for getting access to some data of the shader to export it.
          It is written in Coffee.
          // global variables
          var DiffuseResource;
          var DiffuseDialogVar;               // dialog variable
          var DiffuseVariables;               // temporary saved settings
          // create variable stuct
          struct diffuse_variables
               var sfdiffcolor;
               var sfdifftex;
          // procedures
          InitDiffuseVariables()
               DiffuseVariables = new(diffuse_variables);
               DiffuseVariables->sfdifftex = new(Filename);
               DiffuseVariables->sfdifftex->SetFullString("Please select a texture");
               DiffuseVariables->sfdiffcolor = vector(1.0, 1.0, 1.0);
          // dialog class
          class DiffuseDialog : GeModalDialog
                    DiffuseDialog();
                    CreateLayout();
                    Init();
                    Command(id,msg);
          DiffuseDialog::DiffuseDialog()
               super();
          DiffuseDialog::CreateLayout()
               LoadDialogResource(IDD_SUNFLOW_DIFFUSE,DiffuseResource,0);
               AddDlgGroup(DR_DLGGROUP_OK);
          DiffuseDialog::Init()
               SetColorField(IDC_SUNFLOW_DIFFUSE_COLOR , DiffuseVariables->sfdiffcolor);
               SetString(IDC_SUNFLOW_DIFFUSE_TEXTURE, tostring(DiffuseVariables->sfdifftex->GetFullString()));
          DiffuseDialog::Command(id,msg)
               switch (id)
                    case IDC_SUNFLOW_DIFFUSE_COLOR:
                         DiffuseVariables->sfdiffcolor = GetColor(IDC_SUNFLOW_DIFFUSE_COLOR);
                    break;
                    case IDC_SUNFLOW_DIFFUSE_TEXTURE_BUTTON:
                         if (DiffuseVariables->sfdifftex->FileSelect("Please select a texture", FALSE))
                    break;
                    case IDC_SUNFLOW_DIFFUSE_TEXTURE:
                         DiffuseVariables->sfdifftex->SetFullString(GetString(IDC_SUNFLOW_DIFFUSE_TEXTURE));
                    break;
          //plugin
          class Diffuse:VolumePlugin//ChannelPlugin
               Diffuse();
               GetName();
               GetID();
               // Output(settings, render, p, n, d, t, texflag, vd);
               CalcSurface(settings,render,vd);
               EditData(settings);
          Diffuse::GetName()
               return "SFDiffuse";
          Diffuse::GetID()
               return SunflowDiffuseID;
          /* Diffuse::Output(settings, rd, p, n, d, t, texflag, vd)
               return DiffuseVariables->sfdiffcolor;
          Diffuse::CalcSurface(settings,render,vd)
               var col;
               vd->col = DiffuseVariables->sfdiffcolor;
          Diffuse::EditData(settings)
               DiffuseDialogVar->Open(-1,-1);
          // main
          SunflowDiffuse()
               InitDiffuseVariables();
               var file = GeGetRootFilename(); if (!file) return;
               file->RemoveLast();
               DiffuseResource = new(GeResource,file);
               if (!DiffuseResource)
                    println("    Error: Can't load resource files for SunflowDiffuse");
                    return FALSE;
               DiffuseDialogVar = new(DiffuseDialog);
               Register(Diffuse);
          Ciao and thanks.
          Sascha
          • H
            On 20/04/2007 at 04:39, xxxxxxxx wrote:
            Found it, just included the .coh file in the wrong spot.
            I worked to much on this plug, it was so obvious but i didn't saw it.
            Anyway thanks Matthias.
            Ciao
            • H
              On 20/04/2007 at 11:01, xxxxxxxx wrote:
              I think my joy was overhasty!
              A new problem arised.
              Ok, i've got a menu plugin with the search routine in the first post and the shader plugin. Now I wanted to access the shader data with the resource descriptions like this
              if(mat)
                   var mattype = mat->GetType();
                   println("MATTYPE: ", mattype);
                   var matname = mat->GetName();
                   println("MATNAME: ", matname);
                   var matbc = mat->GetContainer();
                   println("MATCONTAINER: ", matbc);
                   var matdata = matbc->GetData(IDC_SUNFLOW_DIFFUSE_COLOR);
                   println("MATDATA: ", matdata);
              but to my surprise I couldn't access them, in fact I always received a nil for GetData. After searching the forum and the SDK, I found that there are two ways of accomplishing my task. 1.Pluginmessaging or 2.Storing the shader data to an object container.
              So, what would be the best method and how and where is the best place to implement it?
              Ciao
              Sascha
