    Render Settings - setting ( Save path )
    3 Posts 0 Posters 354 Views
      On 27/02/2007 at 08:46, xxxxxxxx wrote:
      Cinema 4D Version:   R10
      Platform:      Mac OSX  ;
      Is there a way to set the "save path" of Render Settings through the API?
      thanks.
        On 27/02/2007 at 09:24, xxxxxxxx wrote:
        Have a look at RenderData in the SDK documentation:
        RDATA_PATH Filename Save path
        and
        RDATA_MULTIPASS_FILENAME Filename Multi-pass path
        These (and all other rendering data) are stored in the RenderData's BaseContainer. Use RenderData::GetDataInstance() to get a pointer to it and set/get values within.
        So, first you'll need to get your document and active render settings and do the magic:
        // Get Active Document
        if (!doc) // panic! ;)
        // Get Active Render settings
        // - you can also traverse those available with
        // - GetFirstRenderData() and rdata->GetNext()
        RenderData* rdata = doc->GetActiveRenderData();
        if (!rdata) // panic some more
        // Get pointer to RenderData's BaseContainer
        BaseContainer* rbc = rdata->GetDataInstance();
        if (!rbc) // panic attack
        // Set the save path
        Filename renderpath = Filename("C:\Data\MyRenders"); // for instance
        rbc->SetFilename(RDATA_PATH, renderpath);
        HTH,
          On 27/02/2007 at 12:39, xxxxxxxx wrote:
          very nice!
          thanks again!
          since the isnatnce is a BaseContainer the other params can be set with SetParameter() e.g.
          rbc->SetParameter(DescID(RDATA_FRAMEFROM), GeData(start) );
