    Material::CopyTo() problems
    5 Posts 0 Posters 504 Views
      On 16/11/2006 at 13:28, xxxxxxxx wrote:
      Cinema 4D Version:   8.2-10.0
      What is wrong with this code? I've tried without COPY_NO_INTERNALS, but the links to the Texture tags are then broken. I've tried calling AliasTrans::Translate after each and at the end (as shown). Is the AliasTrans::Init() document correct (source)? This is getting frustrating as it works to an extent, but the materials don't update properly (show the texture image) and rendering fails.
      // Paste Materials
      Bool GeIPPPaste_Materials(BaseDocument* sdoc, BaseObject* sobj, BaseDocument* ddoc, BaseObject* dobj)
           BaseTag*          stag;
           BaseTag*          dtag;
           TextureTag*          sttag;
           TextureTag*          dttag;
           Material*          smat;
           Material*          dmat;
           GeData               data;
           String               sname;
           BOOL               doTranslate =     FALSE;
           AutoAlloc<AliasTrans> aliastrans;
           if (!(aliastrans && aliastrans->Init(sdoc))) return FALSE;
           // Materials
           for (stag = sobj->GetFirstTag(); stag; stag = stag->GetNext())
                if (!stag->IsInstanceOf(Ttexture))     continue;
                sttag =                                        (TextureTag* )stag;
                sttag->GetParameter(DescID(TEXTURETAG_MATERIAL), data, NULL);
                smat =                                        static_cast<Material*>(data.GetLink(sdoc, Mbase));
                if (!smat)                                   continue;
                sname =                                        stag->GetName();
                for (dtag = dobj->GetFirstTag(); dtag; dtag = dtag->GetNext())
                     if (!dtag->IsInstanceOf(Ttexture))     continue;
                     dttag =                                        (TextureTag* )dtag;
                     dttag->GetParameter(DescID(TEXTURETAG_MATERIAL), data, NULL);
                     dmat =                                        static_cast<Material*>(data.GetLink(ddoc, Mbase));
                     if (!dmat)                                   continue;
                     if (dtag->GetName() != sname)          continue;
                     // Found matching materials, copy
                     if (!smat->CopyTo(dmat, COPY_NO_INTERNALS, aliastrans))     continue; //aliastrans->Translate(TRUE);
                     dmat->Update(TRUE, TRUE);
                     dmat->Message(MSG_CHANGE);
                     doTranslate =     TRUE;
                     break;
           if (doTranslate)     aliastrans->Translate(TRUE);
        On 16/11/2006 at 15:03, xxxxxxxx wrote:
        Okay, this code is mostly working, but I still have to either render or Material Manager->Apply to get the material changes to show in the View.
        How do I do that, please?
        // Paste Materials
             AutoAlloc<AtomArray>     matArray;
             AutoAlloc<AtomArray>     tagArray;
             if (!(matArray && tagArray && aliastrans && aliastrans->Init(sdoc))) return FALSE;
             BaseTag*          stag;
             BaseTag*          dtag;
             TextureTag*          sttag;
             TextureTag*          dttag;
             Material*          smat;
             Material*          dmat;
             GeData               data;
             String               sname;
             // Materials
                       if (!smat->CopyTo(dmat, COPY_NO_BITS, aliastrans)) continue;
                       matArray->Append(dmat);
                       tagArray->Append(dttag);
                       break;
             LONG     count =     matArray->GetCount();
             if (count)
                  for (LONG i = 0; i < count; i++)
                       dmat =          static_cast<Material*>(matArray->GetIndex(i));
                       dttag =          static_cast<TextureTag*>(tagArray->GetIndex(i));
                       dttag->SetMaterial(dmat);
                       dttag->Message(MSG_UPDATE);
          On 16/11/2006 at 15:29, xxxxxxxx wrote:
          Seems that I needed this as well:
                         dobj->Message(MSG_UPDATE);
          Thanks for the conversation! 😉
            On 18/11/2006 at 08:09, xxxxxxxx wrote:
            lol, you are too fast in finding your own bugs. 😉
              On 18/11/2006 at 10:01, xxxxxxxx wrote:
              The worst part is that there is no example of using CopyTo() with Materials. They neglect the little bit about needing to relink them in the Texture tag and I still don't know why the Object needs to be updated - but heck, it works. 😉
