    Generating new object and tag
    3 Posts 0 Posters 327 Views
      On 18/10/2006 at 03:35, xxxxxxxx wrote:
      Cinema 4D Version:   9.5
      I have a Menu-Plugin that is supposed to create a new object and then insert my own tag to that object. But when I run it, it closes C4D without any message whatsoever. Here's my code for the Menu-Plugin Execute:
      Bool GenStation::Execute(BaseDocument *doc)
      BaseObject *op = BaseObject::Alloc(Onull);
      op->SetName("S/C");
      doc->InsertObject(op,doc->GetActiveObject(),NULL,TRUE);
      BaseTag *StationTag = (BaseTag* )TagStation::Alloc();
      op->InsertTag(StationTag);
      EventAdd();
      If I take out the line
      , then everything works fine, but obviously I don't have the tag on my object then ... any ideas?
      cheers, Juergen
        On 18/10/2006 at 04:46, xxxxxxxx wrote:
        If the tag is one of yours, you'll need to call it like this:
        BaseTag* StationTag = PluginTag::Alloc(YOUR_UNIQUE_ID);
        It is also always a good idea to check for NULL (in this case 'op' and 'StationTag' after the Alloc()).
          On 23/10/2006 at 01:27, xxxxxxxx wrote:
          Thanks Robert, that solved the problem! I also included the checks for NULL ...
