    TreeView Header Sorting
    3 Posts 0 Posters 401 Views
      On 06/07/2006 at 07:07, xxxxxxxx wrote:
      Cinema 4D Version:   9.102
      Any information on how this actually works? I see that there is a method TreeViewFunctions::GetHeaderSortArrow(), but there is no arrow on any of the column headers. So, one supposes that I supply the arrow and which column currently is used for sorting?
      Also, would TreeViewFunctions::HeaderClick() be used to possibly initiate sorting (change ascending/descending for instance)?
        On 06/07/2006 at 10:00, xxxxxxxx wrote:
        No clue, as I haven´t used this yet but I´d be interested in knowing it too. 🙂
          On 06/07/2006 at 10:04, xxxxxxxx wrote:
          I think that I have this 'sorted' (bah-dum-bah). 😉
          GetHeaderSortArrow() wants a non-zero value to determine sort direction (though the docs don't specify what values are expected - eh hem). I'm using 0 for no sort, -1/1 for sorted directions.
          HeaderClick() can be used to change sort direction or select a new sort column.
          Here's my code for TreeViewFunctions:
          LONG GetHeaderSortArrow(void* root, void* userdata, LONG lColID)
               rroot =     (ResultsRoot* )root;
               if (rroot->GetSortCol() == lColID)     return rroot->GetSortDir();
               return 0;
          Bool HeaderClick(void* root, void* userdata, LONG lColID, LONG lChannel, Bool bDblClk)
               // Ignore double-clicks and middle/right mouse buttons
               if (bDblClk)                                   return FALSE;
               if (lChannel !=     BFM_INPUT_MOUSELEFT)     return FALSE;
               if (rroot->GetSortCol() == lColID)          rroot->InvertSortDir();
               else                                             rroot->SetSortCol(lColID);
               return     TRUE;
          P.S.: Note that the actual sorting must be done in your own code when conditions warrant (change of column, change of sort direction).
          3D Designer, now you know. 🙂
