    Nonuniform scaling - dilemma
    1 Posts 0 Posters 226 Views
      On 08/05/2006 at 17:02, xxxxxxxx wrote:
      Cinema 4D Version:   9.102
      I've found probably the best solution available for handling shear in nonuniform scaling - SoftImage 'SI transformation' as it's called. It works by sort of rearranging the concatenation of transformation matrices - from classical (in C4D concatenation order) :
      A(global) = B(global) x A(local)
      to 'SI':
      A(global) = AB(pos) x B(rot) x A(rot) x B(scale) x A(scale)
      where AB(pos) = MatrixMove(A(pos) * B(global))
      This works for the most part, but scaling gets wonky as the hierarchy gets deeper. And I can't seem to understand why this occurs, so here is an example of my code which sets the 'bone' rotation:
      // IPPDial.UpdateRotation
      void IPPDial::UpdateRotation(BaseObject* obj, UCHAR sub, Real value)
      // Get the changed rotation component
           BaseContainer*     bc =     obj->GetDataInstance();
           Vector               rotV =     bc->GetVector(IPP_ROTATION);
           if          (sub == CHAN_SUB_X)     rotV.x =     Rad(value);
           else if (sub == CHAN_SUB_Y)     rotV.y =     Rad(value);
           else if (sub == CHAN_SUB_Z)     rotV.z =     Rad(-value);
           bc->SetVector(IPP_ROTATION, rotV);
      // Create an axis-ordered rotation matrix with the updated rotation component
           Matrix               rot;
           UCHAR               order =          bc->GetBool(IPP_RORDER);
           if          (order == ROTORDER_XYZ)     rot = bc->GetMatrix(IPP_ORIENTMATRIX) * MatrixRotZ(rotV.z) * MatrixRotY(rotV.y) * MatrixRotX(rotV.x);
           else if (order == ROTORDER_XZY)     rot = bc->GetMatrix(IPP_ORIENTMATRIX) * MatrixRotY(rotV.y) * MatrixRotZ(rotV.z) * MatrixRotX(rotV.x);
           else if (order == ROTORDER_YXZ)     rot = bc->GetMatrix(IPP_ORIENTMATRIX) * MatrixRotZ(rotV.z) * MatrixRotX(rotV.x) * MatrixRotY(rotV.y);
           else if (order == ROTORDER_YZX)     rot = bc->GetMatrix(IPP_ORIENTMATRIX) * MatrixRotX(rotV.x) * MatrixRotZ(rotV.z) * MatrixRotY(rotV.y);
           else if (order == ROTORDER_ZXY)     rot = bc->GetMatrix(IPP_ORIENTMATRIX) * MatrixRotY(rotV.y) * MatrixRotX(rotV.x) * MatrixRotZ(rotV.z);
           else if (order == ROTORDER_ZYX)     rot = bc->GetMatrix(IPP_ORIENTMATRIX) * MatrixRotX(rotV.x) * MatrixRotY(rotV.y) * MatrixRotZ(rotV.z);
      // SI transformation
           Matrix               mg =          obj->GetUpMg();
           mg =               MatrixMove(obj->GetPos()*mg) * HPBToMatrix(MatrixToHPB(mg)) * rot * MatrixScale(Vector(Len(mg.v1),Len(mg.v2),Len(mg.v3))) * MatrixScale(obj->GetScale());
           obj->SetMg(mg, FALSE);
           obj->Message(MSG_UPDATE);
      For position and scale, the same basic format applies for the SI transformation. If anyone can spot an error or has a better algorithmic approach, love to hear about it.
