    Selecting outside treeview items
    2 Posts 0 Posters 336 Views
      On 29/10/2005 at 03:15, xxxxxxxx wrote:
      Cinema 4D Version:   9.1
      This might be a bit complicated
      I have a TreeView gadget that is currently populated by 700 items.
      Each of these items is in fact a BaseObject that I create in memory that I dont insert into the document.
      I then use the BaseContainer of each of these virtual objects to store data regarding the treeview state.
      One important part of these BaseContainers is that I have set a link to point to an object thats already in the document.
      Then when the user clicks on a treeview item, I check the link in the basecontainer, make sure its valid, and use doc->SetActiveObject() to select the object.
      I do this inside the TreeViewFunctions::Select Method.
      now I have a problem, it works fine but if I click on a item OUTSIDE the treeview list (for example, if all the items are collapsed, and i click below the last item)
      My treeview goes on a frenzy and calls Select for every 700 items in the treeview, thus creating a massive slow down as the plugin is busy processing all the items
      I can't work out why the treeview executes the Select method so many times.
      Its fine when the user actually click a valid item in the treeview, Select is called around 3 times which is fine.
        On 29/10/2005 at 07:50, xxxxxxxx wrote:
        I think I have worked out what is happening.
        When you click an invalid item in the treeview, the treeview attempts to de-select everything, so it calls TreeViewFunction::Select() for every object while passing SELECTION_SUB as the mode parameter
