    Filling a COFFEEexpressionTag with Data
    SDK Help
    0
    • H
      On 09/09/2005 at 06:05, xxxxxxxx wrote:
      Cinema 4D Version:   9
      I need to know how i can fill a coffeeexpression Tag with some source code(also COFFEE) via a plugin.
      var coffeeTag=AllocTag(Tcoffeeexpression);
      //here i have to fill the tag with data!?
      myObject->InsertTag(coffeeTag);
      How does it work?
      • H
        On 11/09/2005 at 10:05, xxxxxxxx wrote:
        i have the same question
        but the AllocTag always makes an ERROR when compiling.
        it syas varibale or function expected, instead of this Tcoffeeexpression...
        maybe we must enter a number?
        • H
          On 12/09/2005 at 01:04, xxxxxxxx wrote:
          the code:
          works fine. But i can't fill the tag with some source code.
          Whatfor do we need a number?
          • H
            On 06/10/2005 at 08:19, xxxxxxxx wrote:
            I#m new with Coffee.
            But what is happen when you user Number: 5675 ?
            var coffeetag=Alloctag(5675);
            myObject->Inserttag(coffeetag);
            I'm looking for a chance to make a coffee-Tag with Code, too!
            Expresso-Tag can be create, but can't filled with Nodes and connections 😞
            Maybe Coffe is a way!
            Anybody knows how fill a coffe-Tag with code?
            • H
              On 07/10/2005 at 07:22, xxxxxxxx wrote:
              No Idea ?
              • H
                On 07/10/2005 at 12:45, xxxxxxxx wrote:
                Maybe I found a hint for that:
                C:\Programme\MAXON\CINEMA 4D R9\resource\coffeesymbols.h
                I think that all constant of Coffee.
                There are:
                COFFEEEXPRESSIONTAG_PASS=1500,
                COFFEEEXPRESSIONTAG_TEXT=1000,
                Is Text maybe for Coffee-Code ?
                How can I put it in a Tag?
                With GetContainer and SetContainer ?
                • H
                  On 08/10/2005 at 04:34, xxxxxxxx wrote:
                  Is is Possible with that:
                  var Tag = AllocTag(5675);
                  if (!Tag) {
                   println("could not allocate new MOCCA IK tag");
                   return;
                  var ccode = Tag->GetContainer();
                  ccode->SetData(COFFEEEXPRESSIONTAG_TEXT,"Hello");
                  Tag->SetContainer(ccode);
                  if (!object->InsertTag(Tag)) {
                   println("could not add MOCCA IK tag to current object");
                   return;
                  • H
                    On 09/10/2005 at 17:15, xxxxxxxx wrote:
                    I'm not sure if I'm understanding the question, but if you are just looking for a way to create a plugin tag, the following page and its links helped me immensely:
                    http://www.geocities.com/eago9/coffeetuts/index.html
                    I hope this helps.
                    Aaron
                    • H
                      On 10/10/2005 at 15:35, xxxxxxxx wrote:
                      I have find a Way.
                      And publish it here: http://www.total3d.de/index.php?b=mmdocu&wo=viewkapitel&bo=10&ka=82#titel
