    cycle
    13 Posts 0 Posters 1.0k Views
      On 07/04/2005 at 16:17, xxxxxxxx wrote:
      Have you checked to see what messages are sent with a change of the cycle box value? This will give you an idea of what to look for.
        On 10/04/2005 at 13:29, xxxxxxxx wrote:
        Robert is right; look at what's sent to Message() when the cycle field is changed. (Assuming it's in a dialog box, not in the attributes manager.)
          On 11/04/2005 at 01:54, xxxxxxxx wrote:
          It is in the attributes manager.
          I detect the change now by reading the value in the next execute pass (tag plug).
          But i woul like to trap it on the moment its selected.
            On 11/04/2005 at 04:28, xxxxxxxx wrote:
            when you change any description entry, I am sure the Message MSG_DESCRIPTION_VALIDATE is definetly called (when you are in the AM). So check for it in your Message function and do whatever you want. 🙂
            HTH
            Katachi
            P.S.: A "thanks" isn´t too hard...
              On 11/04/2005 at 10:45, xxxxxxxx wrote:
              Oh, of course, yes..., thanks..i'm sorry.
              And: indeed, the VALIDATE message is the one, great, thanks again.
                On 06/07/2008 at 09:37, xxxxxxxx wrote:
                That's great, but how am I able to see which one is changed? Do I have to control it manually or is there something else?
                  On 06/07/2008 at 12:57, xxxxxxxx wrote:
                  Not sure if i remember well but i think it was something like this....
                  > \> Bool YOURCLASS::Message(GeListNode \*node, LONG type, void \*data) \> { \>      DescriptionCommand \*dc   = (DescriptionCommand\* ) data; \> \>      switch (type) \>      { \>       \>           case (MSG_DESCRIPTION_VALIDATE) :                               \>           { \>                if (dc->id[0].id == YOUR_ID) \>                { \>                     // do what you need to do \>                     break; \>                } \>           } \>
                  Succes!
                  Jan
                    On 07/07/2008 at 09:21, xxxxxxxx wrote:
                    By that I always get the id 0. I think it's only for buttons. Isn't it DescriptionValidate instead of DescriptionCommand in this case?
                      On 08/07/2008 at 00:54, xxxxxxxx wrote:
                      Hm,
                      I'm using it exactly like this, you must have a problem elswhere?
                      Jan
                        On 09/07/2008 at 15:59, xxxxxxxx wrote:
                        Maybe, but I have no idea where. I gave every single element a unique long value in the *.h-file. As I said, the buttons work fine this way, but not the other things. This is my code:
                        \>  Bool x::Message(GeListNode *node, LONG type, void *t_data)
                        \>       switch (type)
                        \>       case MSG_DESCRIPTION_COMMAND:
                        \>                 DescriptionCommand *dc = (DescriptionCommand* ) t_data;
                        \>                 if (dc->id[0].id==REFRESH)
                        \>                 if (dc->id[0].id==NEUE_ZUFALLSWERTE)
                        \>       case MSG_DESCRIPTION_VALIDATE:
                        \>                 GePrint(LongToString(dc->id[0].id));
                        \>       return true;
                          On 09/07/2008 at 16:08, xxxxxxxx wrote:
                          Duh. MSG_DESCRIPTION_COMMAND has a DescriptionCommand in the t_data but MSG_DESCRIPTION_VALIDATE has a DescriptionValidate in t_data. Unfortunately, DescriptionValidate does NOT contain the Description ID of the command that triggered the message so you have to be general about it here (i.e.: check every description that falls under validation).
                          Don't ask me, ask Maxon. 🙂
