    Where i wrong?
    6 Posts 0 Posters 551 Views
      On 24/03/2005 at 01:29, xxxxxxxx wrote:
      Cinema 4D Version:   9.1
      have a little problem... i have make this simple program with coffee where i count the point of one polygon that have a x coord equal to zero:
      var cnt=op->GetPointCount();
      var p=op->GetPoints();
      var i=0;
      var b=0;
      if (!cnt) return TRUE; // no points, nothing to do
      for (i=0; i<cnt; i++)
      if (p _.x==0) b++;
      println (p _); //See the point coordinate into console
      println (b);
      Why b contains ZERO?!?!?
      Is right that the value of array p _can i identify with
      p _.x , p _.y , p _.z ?
      Tnx for the answer !
        On 24/03/2005 at 10:38, xxxxxxxx wrote:
        p is an array (a list with all points in it). You can access each point of the array with the [] operator.
        if(p _.x==0.0) b++;
        //or maybe p _- >x, not sure, too long ago I used COFFEE 🙂
          On 24/03/2005 at 14:23, xxxxxxxx wrote:
          3D Designer, looking carefully at the code listing above, methinks that he actually has that part, it just got reinterpret_cast-ed 😉 into italics.
          Considering that [ i ] is ubiquitous beyond belief in C/C++/COFFEE programming (not to mention nearly every other language), why the web maintainers haven't found a way to exclude [ i ] from [ CODE ][ /CODE ] sections is beyond me...
          Time to have a discussion with Web Wiz Forums, perhaps?
          ETA: Yes, COFFEE always accesses objects with '- >' and not '.', at least in my experience.
            On 24/03/2005 at 15:54, xxxxxxxx wrote:
            reinterpret_cast-ed, *ROFL* ;D
            yes, that might be possible. 🙂
            And concerning the access, the COFFEE docs say
            Vector acces operator = . (v.x)
            So it should be p _.x me thinks. 🙂
              On 24/03/2005 at 18:12, xxxxxxxx wrote:
              Well, here's some of my own COFFEE code relating to Object points:
                   // - Set Polygon Object's point positions to those of the Null Objects
                   var x = 0;
                   var noVector;
                   var ptArray = polyObject->GetPoints();
                   for (obj = doc->GetFirstObject(); obj; obj = obj->GetNext())
                        if (instanceof(obj, NullObject))
                             noVector = obj->GetPosition();
                             ptArray[x].x = noVector.x;
                             ptArray[x].y = noVector.y;
                             ptArray[x].z = noVector.z;
                             x++;
                   polyObject->SetPoints(ptArray);
              to protect the innocent. 🙂
                On 25/03/2005 at 00:33, xxxxxxxx wrote:
                Tnx for the answers !! 🙂
                Infact, i have writed p _.x but when i have put the program into code Tag, it have removed It !!
                Tnx to all !! 🙂
