    How to get sphere coordinates
    s26c++windows
    6 Posts 2 Posters 2.1k Views
    • P Offline
      pchg
      Hello colleagues, I used C++ to write the C4D S26 plugin on Windows 10, I import .abc and want to get the center point coordinates of each sphere, not the vertex coordinates
      BaseObject* obj = doc->GetActiveObject();
      PointObject* pointObj = static_cast<PointObject*>(obj);
      Int32 pointCount = pointObj->GetPointCount();
      Vector* points = pointObj->GetPointW();
      const ::Matrix globalMtx = pointObj->GetMg();
      for (Int32 i = 0; i < pointCount; ++i)
        Vector site = pointObj->GetMg() * points[i];
        GePrint("Frame " + String::IntToString(count) + ": " + String::VectorToString(site));
      • P Offline
        pchg
        Thanks in advance!
        • i_mazlovI Offline
          i_mazlov @pchg
          Hello @pchg ,
          Normally importers in cinema reflect the geometry contained in the original file, or in other words what's contained in the original scene will be in cinema in the closest possible state.
          In your case your original scene contains a single geometry that consists of multiple so-called "polygon islands". It looks to me the easiest way to proceed for you would be to first split your geometry into a list of distinct objects (spheres) and then iterate over them separately.
          You can achieve this by calling SendModelingCommand with the MCOMMAND_EXPLODESEGMENTS cmd id. The effect you need is the same as if you were to run command "Polygon Islands to Objects" from within cinema GUI.
          Please note, recently there was related discussion on this command call: c4d.MCOMMAND_EXPLODESEGMENTS makes target object dead.
          The SMC command will return a hierarchy of polygon objects to you, which you can then normally traverse (using functions GetDown() and GetNext() of BaseObject) and retrieve the transform information using related functions: BaseObject - Properties - PSR.
          Ilia
          P 2 Replies Last reply Reply Quote 0
          • P Offline
            pchg @i_mazlov
            Thanks @i_mazlov
            I want to get the coordinate information of all spheres under this editable object
            BaseDocument* doc = GetActiveDocument();
            ModelingCommandData mcd;
            mcd.doc = doc;
            mcd.op = obj;
            const bool result = SendModelingCommand(MCOMMAND_EXPLODESEGMENTS, mcd);
            Wrong result, result = false, or whether it should be done
            const bool result = SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, mcd);
            BaseObject* res = static_cast<BaseObject*>(mcd.result->GetIndex(0));
            while (res != nullptr)
            Vector points = res ->GetAbsPos();
            res = res -> GetNext();
            but only one coordinate
            • P Offline
              pchg @i_mazlov
              @i_mazlov Thanks
              BaseObject* activeObject = doc->GetActiveObject();
              if (!activeObject)
              	return break;
              mcd.doc = doc;
              mcd.op = activeObject;
              if(result)
              	EventAdd();
              Although I got all the spheres, all the sphere animation was lost, What should I do?
              • i_mazlovI Offline
                i_mazlov
                Hi @pchg ,
                This thread is almost a full duplicate of your adjacent thread: How to preserve the animation of a sphere. The answer is provided there.
                Ilia
