    Edge ring selection
    2024pythonwindows
    2 Posts 2 Posters 692 Views 1 Watching
    • T Offline
      Tpaxep
      Hi folks, I am actively trying to learn Python for Cinema 4D, and lately I have been struggling with edge selection, specifically the Loop and Ring functions.
      I got the code working as expected in r21, but in r25 and 2024 it no longer works, I have been trying to figure out what the problem is, but alas, I have not been able to. I would really appreciate it if you could show me what I am missing
      from c4d import utils
      def select_ring_edge(obj, edge_id):
          bc = c4d.BaseContainer()
          bc.SetData(c4d.MDATA_RING_EDGE, edge_id)
          bc.SetData(c4d.MDATA_RING_SELECTION, c4d.SELECTION_NEW)
          result = c4d.utils.SendModelingCommand(
              command=c4d.ID_MODELING_RING_TOOL,
              list=[obj],
              mode=c4d.MODELINGCOMMANDMODE_EDGESELECTION,
              bc=bc,
              doc=c4d.documents.GetActiveDocument(),
              flags=c4d.MODELINGCOMMANDFLAGS_CREATEUNDO
          return result
          obj = doc.GetActiveObject()
          if obj is None:
              c4d.gui.MessageDialog("select obj.")
          edge_index = 3
          result = select_ring_edge(obj, edge_index)
          if result:
              print("DONE")
              print("ERROR")
      • M Offline
        m_adam
        Hi @Tpaxep,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: How to Ask Questions.
        About your First Question
        The tool has indeed been updated, but the docs were not.
        Here is how to call it. Note that you have to pass a polygon index, this is mandatory and it needs to be adjacent to one of the vertex to indicate a direction of the ring selection. Here is your script adapted, to be run on a sphere that was made editable.
        def select_ring_edge(obj, v1Id, v2Id, polyId):
            bc.SetData(c4d.MDATA_RING_SEL_STOP_AT_SELECTIONS, False)
            bc.SetData(c4d.MDATA_RING_SEL_STOP_AT_NON_QUADS, False)
            bc.SetData(c4d.MDATA_RING_SEL_STOP_AT_POLES, True)
            bc.SetData(c4d.MDATA_RING_BOTH_SIDES, False)
            bc.SetData(c4d.MDATA_RING_SWAP_SIDES, False)
            bc.SetData(c4d.MDATA_RING_FIRST_VERTEX, v1Id)
            bc.SetData(c4d.MDATA_RING_SECOND_VERTEX, v2Id)
            bc.SetData(c4d.MDATA_RING_POLYGON_INDEX, polyId)
                list=[obj],
                bc=bc,
                flags=c4d.MODELINGCOMMANDFLAGS_NONE
            return result
            if obj is None:
            firstVertex = 346
            secondVertex = 347
            polygonIndex = 312
            result = select_ring_edge(obj, firstVertex, secondVertex, polygonIndex)
            if result:
                print("DONE")
                print("ERROR")
        Note that the same settings also apply for the ID_MODELING_LOOP_TOOL, just modify RING by LOOP in the constant so MDATA_RING_SEL_STOP_AT_SELECTIONS become MDATA_LOOP_SEL_STOP_AT_SELECTIONS.
