    Tree view boolean column bug
    pythonwindows
    2 Posts 2 Posters 546 Views 1 Watching
    • G Offline
      Gregor M
      I have a problem with a tree view custom gui.
      When I toggle any boolean field other than the bottom one it also toggles the top most one by itself.
      import weakref
      # Control IDs
      ID_TREEVIEW          = 1000
      ID_BTN_NEW_FOLDER    = 1001
      ID_BTN_DELETE        = 1002
      ID_PATHFIELD         = 1003
      # Tree column IDs
      ID_CHECK = 1  # Checkbox column
      ID_NAME  = 2  # Name column
      # Basic Entity
      class Entity:
          def __init__(self, is_root=False, name="Folder"):
              self.is_root = is_root
              self.name = name if not is_root else "Root"
              self.checked = False
              self.opened = True
              self.selected = False
              self.parent = None
          def AddChild(self, child):
              child.parent = weakref.ref(self)
              self.children.append(child)
          def GetChildren(self):
              return self.children
          def GetParent(self):
              return self.parent() if self.parent else None
      # TreeView Functions
      class SimpleTreeFunctions(c4d.gui.TreeViewFunctions):
          def __init__(self, dlg):
              self._dlg = weakref.ref(dlg)
              # Create the global Root entity.
              self.root_entity = Entity(is_root=True)
              # Top-level entities: Root and any added Folders (as siblings).
              self.entities = [self.root_entity]
          def GetFirst(self, root, userdata):
              return self.entities[0] if self.entities else None
          def GetDown(self, root, userdata, obj):
              return obj.GetChildren()[0] if obj.GetChildren() else None
          def GetNext(self, root, userdata, obj):
              parent = obj.GetParent()
              siblings = parent.GetChildren() if parent else self.entities
              idx = siblings.index(obj) + 1
              return siblings[idx] if idx < len(siblings) else None
          def GetPred(self, root, userdata, obj):
              idx = siblings.index(obj) - 1
              return siblings[idx] if idx >= 0 else None
          def GetId(self, root, userdata, obj):
              return id(obj)
          def Select(self, root, userdata, obj, mode):
              # Clear all selections if a new selection is made.
              if mode == c4d.SELECTION_NEW:
                  for e in self._AllEntities():
                      e.selected = False
              if mode in [c4d.SELECTION_NEW, c4d.SELECTION_ADD]:
                  obj.selected = True
              elif mode == c4d.SELECTION_SUB:
                  obj.selected = False
              self._dlg().UpdatePathField()
          def IsSelected(self, root, userdata, obj):
              return obj.selected
          def IsOpened(self, root, userdata, obj):
              return obj.opened
          def Open(self, root, userdata, obj, onoff):
              obj.opened = onoff
          # Toggle checkboxes.
          def SetCheck(self, root, userdata, obj, column, checked, msg):
              if column == ID_CHECK:
                  # If the object is global Root, only change when directly clicked.
                  if obj.is_root:
                      obj.checked = bool(checked)
                      # When toggling a Folder, ensure the Root's state is preserved.
                      global_root = self.root_entity
                      original = global_root.checked
                      global_root.checked = original
              self._dlg()._treegui.Refresh()
          def IsChecked(self, root, userdata, obj, column):
              if obj.checked:
                  return c4d.LV_CHECKBOX_CHECKED | c4d.LV_CHECKBOX_ENABLED
              return c4d.LV_CHECKBOX_ENABLED
          def GetName(self, root, userdata, obj):
              return obj.name
          def SetName(self, root, userdata, obj, newname):
              obj.name = newname
          def _AllEntities(self):
              # Recursively iterate through all entities.
              def recurse(lst):
                  for ent in lst:
                      yield ent
                      yield from recurse(ent.GetChildren())
              return recurse(self.entities)
          def DeletePressed(self, root, userdata):
              # Delete selected entities, except the global Root.
              to_delete = [e for e in self._AllEntities() if e.selected and not e.is_root]
              for e in to_delete:
                  parent = e.GetParent()
                  if parent:
                      parent.GetChildren().remove(e)
                      self.entities.remove(e)
      # Main Dialog: Contains the tree view, add and delete buttons, and a text field.
      class SimpleTreeDialog(c4d.gui.GeDialog):
          def __init__(self):
              self.treeData = None
              self._treegui = None
          def CreateLayout(self):
              self.SetTitle("Simple Tree (Folders as Siblings)")
              # Buttons: Add Folder and Delete Selected.
              self.GroupBegin(100, c4d.BFH_SCALEFIT, 2, 1)
              self.AddButton(ID_BTN_NEW_FOLDER, c4d.BFH_SCALEFIT, name="Add Folder")
              self.AddButton(ID_BTN_DELETE, c4d.BFH_SCALEFIT, name="Delete Selected")
              self.GroupEnd()
              # A text field to display a simple representation of the tree.
              self.AddEditText(ID_PATHFIELD, c4d.BFH_SCALEFIT)
              self.AddSeparatorH(0, c4d.BFH_SCALEFIT)
              # Create the TreeView.
              bc = c4d.BaseContainer()
              bc.SetBool(c4d.TREEVIEW_BORDER, True)
              self._treegui = self.AddCustomGui(ID_TREEVIEW, c4d.CUSTOMGUI_TREEVIEW, "",
                                                c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 400, 300, bc)
              if not self._treegui:
                  print("Error: Could not create TreeView")
                  return False
              # Set up the tree layout: a checkbox and name column.
              layout = c4d.BaseContainer()
              layout.SetLong(ID_CHECK, c4d.LV_CHECKBOX)
              layout.SetLong(ID_NAME, c4d.LV_TREE)
              self._treegui.SetLayout(2, layout)
              self._treegui.SetHeaderText(ID_CHECK, "Check")
              self._treegui.SetHeaderText(ID_NAME, "Name")
              # Initialize tree data: global Root is the first (and fixed) sibling.
              self.treeData = SimpleTreeFunctions(self)
              self._treegui.SetRoot(None, self.treeData, None)
              self._treegui.Refresh()
              self.UpdatePathField()
          def Command(self, id, msg):
              if id == ID_BTN_NEW_FOLDER:
                  self.AddFolder()
              elif id == ID_BTN_DELETE:
                  self.treeData.DeletePressed(None, None)
          def AddFolder(self):
              # Create a new Folder entity and add it as a sibling (top-level).
              new_entity = Entity(is_root=False, name="Folder")
              self.treeData.entities.append(new_entity)
          def UpdatePathField(self):
              # Build a simple string showing the names of top-level entities.
              names = [ent.name for ent in self.treeData.entities]
              self.SetString(ID_PATHFIELD, " | ".join(names))
      if __name__=='__main__':
          dlg = SimpleTreeDialog()
          dlg.Open(c4d.DLG_TYPE_ASYNC, pluginid=0, defaultw=500, defaulth=400)
      • M Offline
        m_adam
        Hi @Gregor-M please make sure that your script is executable before sending it to us. Since in it's current state it does raise
        Traceback (most recent call last):
          File "scriptmanager", line 53, in GetDown
          File "scriptmanager", line 33, in GetChildren
        AttributeError: 'Entity' object has no attribute 'children'. Did you mean: 'GetChildren'?
        I added self.children = [] within the __init__ of Entity and it fixed the issue but this indicate that you are working on a different version than us. But even with it I'm not able to reproduce any issue and everything is working as expected.
        With that's said your else statement within the SetCheck looks very suspicious and I won't be surprised that the behavior you are experiencing is coming from this else statement.
        Finally note that you can call the function TreeViewCustomGui.SetRoot to define a root. Then the root argument that is available in all functions will be pointing to it.
